Elliott Omnimill 00
Elliott Omnimill 00
Home › Forums › General Questions › Elliott Omnimill 00
Viewing 2 posts - 1 through 2 (of 2 total)
  • #358624
    graham turner
      @grahamturner91985
      Hi Guys,
      Over the last 12 months I’ve replaced all bearings and drive belts plus cleaning etc on my Elliott Omnimill 00 machine . I’ve noticed that the spindle speed lever is very tight to move foward and backwards between the two low and high speed selections . I’ve tried readjusting the tension on the spring ball bearing
      Grub screw on the gear shaft , but doesn’t seem to make any difference on the stiffness on the movement of the lever. Does anyone own a Elliott Omnimill 00 and have had this problem or have any idea how to rectify this ? Thanks Graham
      #26035
      graham turner
        @grahamturner91985
        Tight spindle speed lever for horizontal milling
