Plain V belt or Cogged V belt ?
Home › Forums › General Questions › Plain V belt or Cogged V belt ?
  • #341042
    C J
      @cj88518
      I fitted a Dunlop Z42 10 x 6mm V belt to my pillar drill and swear it's causing a vibration from where the belt is joined as it has a low and regular frequency.
      I see there are ZX42 cogged V belts with the same dimensions that are claimed to run smoother and be more energy efficient etc.
      Has anyone tried one of these belts and know if the ZX section a direct replacement for a Z section belt ?
      In the dark. sad
      #25805
      C J
        @cj88518
        #341048
          I use cogged V belts on my Myford and am very pleased with the results. Purrs along beautifully. They seem to cope with the small pulleys better than standard belts.
          #341121
          Nick Hulme
            @nickhulme30114
            There is less distortion of the rubber required to get around a given radius so less conversion of energy to heat, whilst still maintaining grip and drive to the same depth as a standard belt. This type of belt was used in automotive applications prior to the adoption of Poly Vee for smoother running and less power loss.
            #341270
            Ian S C
              @iansc
              The notched V belt is second only to the link type belt for smoothness as V belts go.
              Ian S C
              #341282
              Alistair Robertson 1
                @alistairrobertson1
                We had an old american Gisholt capstan lathe that used 6 B-section belts. The tensioner ran on the back of the belt and after 6 months the belts started breaking up. It took about 6 hours to change out and was not a cheap operation.
                We found a bit of paper stuffed in the cover from a fitter in Cleveland, Ohio that showed he had been replacing belts every six months as well! There was still a plate on the headstock that said "This Machine Conforms to Orders of The War Production Board"
                We replaced the belts with notched belts and when the company was sold seven years later the belts were as good as new.
                I recently bought a Warco pillar drill and it suffered from a lot of vibration when running. Replacing both belts with good quality notched belts transformed the drill, a totally different machine and a pleasure to use!
                #341289
                C J
                  @cj88518
                  Ian S C, The pulley grooves on my Meddings Driltrue are not that deep so I think a link type of belt might bottom in them, which I don't want to happen, but I take you're word for the smoothness.
                  Alistair, I have already ordered a cogged V belt for my drill and if it eliminates the vibration I will get one for my milling machine as that also suffers from a vibration on high speeds which I got around by putting the belt on a lower speed and adjusting the overall speed with my electronic drive.
                  #341292
                  C J
                    @cj88518
                    This same subject on practiclemachinist.com  **LINK**
                    Edited By C J on 13/02/2018 13:33:42
