What steel to use
What steel to use
Home Forums General Questions What steel to use
  • #278878
    James Walton
      @jameswalton44680
      Hi there, I am currently restoring a 1930 Colchester Master and have stripped it down to the last nut and bolt. The engineering carnage is not as bad as I thought however I will have to make a number of gear wheels. 5 Change wheels, forward and reverse tumbler gears and main spindle drive wheels. Most importantly longitudinal and cross feed drive wheels. What steel should I use as some of the wheels transferring power have to have significant strength.imag1369.jpg
      #25019
      James Walton
        @jameswalton44680
        1930 Colchester Master What happens when gin and ebay collide
        #278885
        mechman48
          @mechman48
          Erm… restoring? dont know good luck…
          George
          #278891
          Chris Gunn
            @chrisgunn36534
            James, EN24 for gears would be good.
            Chris Gunn
            #278894
            James Walton
              @jameswalton44680
              Cheers Chris.
              #278902
                Hi James,
                It may be a challenge, but it looks essentially complete and should be a rewarding journey.
                You won't need exceptionally strong steel, the original change gears were probably cast iron.
                  Hope your lead screw and feed shaft are still straight after having that sling round themblush
                  #278933
                  Ady1
                    @ady1
                    ta-daaaaa!
                    #279067
                    mechman48
                      @mechman48
                      Looking good now James…
                      George.
