I built this hybrid Shreckling / KJ 66 engine around 2001 ,some photos
in the album "Turbine" uses a Shreckling type aluminium compressor
wheel (2014 T6) and a 718 inconel turbine wheel.Starts and runs
very easily , runs at 100 K at about 630 deg c EGT ,thrust is low by
modern standards at about 6 lb .Have accidentially run to 140 K
overfueling and still survived.Uses standard 8 x 22 ballraces.
Some useful download plans can be seen here from Gerald Rutten
members.tele2.nl/geraldensuzanne/turbines.htm
Using the same case size as the Shreckling engine he is getting
about 40 lb thrust.
These engines are no more difficult to build than anything else,
they do need accuracy ,concentricity ,and balance.
