myford ml10 lead screw removal
Home Forums General Questions myford ml10 lead screw removal
  • #207708
    paul 1950
      @paul1950
      #24160
      paul 1950
        @paul1950
        #207712
          Not certain, but: Based on 'typical' Myford engineering, the handle probably acts as a lock-nut … Hold the hexagon with an open-ended spanner, and 'bump' the handle with the butt of your [other] hand.
          [don't blame me if I'm wrong]
          Edit: corrected a typo.
          Edited By Michael Gilligan on 13/10/2015 20:04:06
          #207718
          NJH
            @njh
            Relax Michael
            You are right!
            Paul – proceed as advised.
            Norman
            #207733
            Clive Hartland
              @clivehartland94829
              It should run in a sintered bearing shell in that casting so remember to oil it on replacing. A bit difficult to set up for minimum backlash as the handle and nut seem to pull away a bit. Persevere until you get minimum backlash
              #207750
              paul 1950
                @paul1950
                thanks everyone will have a go when I get back from the car boot sale. its not going back together I bought it to sell on as spares, paid over the top for it so its a bit of a gamble.
                #207822
                edintheclouds
                  @edintheclouds
                  Hi Paul,
                  Does the ML10 have a lead screw clutch fitted, or any other extras?
                  Les
                  #207829
                  paul 1950
                    @paul1950
                    it has a dog clutch that i will be selling with the lead screw now that i have got it off
                    #207833
                    edintheclouds
                      @edintheclouds
                      I would be interested in buying them, what price would you put on them?
                      #207834
                      paul 1950
                        @paul1950
                        they will not be cheap at the moment as i paid to much for the lathe over £500.00 once i have got my money back i drop the prices on what is left to give me a bit of profit and to clear some room. going to put in on for £75.00 plus postage in anyone buys from the forum it will be 10% cheaper
                        #504923
                        rik arry
                          @rikarry
                          I know old post but looking to do the same to remove lead screw does it just pull out ? Does anyone know what the pin does ?
                          Thanks in advance
                          #534932
                          Eric Lucas
                            @ericlucas71410
                            That is for holding the bush
                            only needs removing to replace the bush
