What uses can I use this for
Home Forums General Questions What uses can I use this for
  • #116217
    martin perman 1
      @martinperman1
      Gentlemen,
      I am type 2 Diabetic and recently I've been having difficulties controlling my sugar levels and the Doctors have now got me, since yesterday, injecting a drug into myself. The practitioner nurse instructed me in the use of what's best described as a pen.
      As a working engineer I'm fascinated with this device for two reasons, the first is how do they make a 0.25 mm OD tube i.e. the needle and my second thought is there must be a use for the pen when the drug is finished. Its about the size of a large pen which at one end you can fit the disposable needle and at the other end is a dial which is adjustable from zero to 1.8mg in increments of 0.6mg and also a small pump to inject the liquid through the needle.
      My initial idea is a lubricating device for small amounts, what thoughts have you.
      Martin P
      #22568
      martin perman 1
        @martinperman1
        #116218
        KWIL
          @kwil
          Certainly just the job for a micro oiler.
          #116219
          keithmart
            @keithmart
            Hi
            As a diabetic myself, i have pondered the same problem. havn't found a use yet.
            BTW insulin is a hormone not a drug cheeky
            regards
            Keith
            Leeds UK
            #116220
            John Stevenson 1
              @johnstevenson1
              I though a hormone was a yell out of a brothel window ????????????
              #116221
              martin perman 1
                @martinperman1
                Keith,
                I'm injecting Liraglutide not Insulin.
                Martin P
                #116223
                Sub Mandrel
                  @submandrel
                  I don't know how they make the tube, but I do know a bloke who works in quality assurance*.
                  He says he knew someone at a British firm who were sent a little jewel box by an American firm containing 'the worlds smallest steel tube'.
                  He also says they sent it back with one of their own steel tubes threaded through it
                  A man of many talents, he also sang on the kiddy chorus of 'I Wish It Could Be Christmas Every Day".
                  #116225
                  NJH
                    @njh
                    That's a very old story, I heard it years ago – I just hope it's true!
                    (Although today, in this age of conspicuous consumption and " bigger is better" attitudes maybe being sent the worlds "biggest" tube and returning it, with 6 others, inside a larger tube would seem, to some, more impressive.)
                    Norman
                    #116226
                    RJW
                      @rjw
                      Martin, Sounds like they may work as watch oilers!
                      Back in the mists of time during my motor engineering days in Doncaster, the story going around then was that a company in America sent the (long time defunct) International Harvesters a drill bit for their perusal, this drill bit was microscopic in size aparrently, but the IH boffins sent the drill back to them with hole neatly drilled down the middle!
                      Not sure how true it is, but I'm sure it will have happened somewhere at some time!
                      Dave Jones 1
                        @davejones1
                        The one I have heard, is that during the beginning for the second world war, the merlin engines that the british built did not require a gasket due to the finish of the parts. When the plans were given to the Americans for Packard to build under licence, a gasket had to be added as they could not finish the pieces to the same quality. I am not sure how true it is, but a nice story all the same.
                        #116232
                          Posted by Stub Mandrel on 06/04/2013 17:43:14:
                          Neil,
                          They make bigger tube and draw it down through a series of dies.
                          P.S.    Nice video, here
                          Edited By Michael Gilligan on 06/04/2013 19:27:26
                          #116234
                          Speedy Builder5
                            @speedybuilder5
                            Hi Stub, the name of the firm was Accles and Pollock and Dad had one of their samples tubes inside the aforesaid American one mounted on a sales brochure card. To prove the smaller tube was in fact a tube, a thin piece of wire was threaded down it. I am not sure, but it may have been been given away at the Great Exdhibition (1950 ??)
                            Bob
                            #116236
                              Maybe 1963 ?
                              Speedy Builder5
                                @speedybuilder5
                                Follow this link for the Accles and Pollock small tube story. Look on page 18, just underneath the cartoon of the 'scientist/engineer'
                                NJH
                                  @njh
                                  Hi Bob
                                  The "Great Exhibition" usually refers to the 1851 exhibition at the Crystal Palace. The 1951 exhibition was the Festival Of Britain. I think minature tubes are more likely to have been available in 1951 rather than 1851.
                                  They had a large "Skylon" I think it was called – like a huge silver cigar I seem to recall. ( Pretty small beer by todays constructions I expect) I think it was an attempt at a bit of pick up for a nation in the aftermath of the war. I remember my Dad going and, much as I wanted to go too, I was deemed too young ( at the age of 6! )
                                  Cheers
                                  Norman
                                  Edited By NJH on 06/04/2013 20:15:15
                                  #116239
                                  Sub Mandrel
                                    @submandrel
                                    Sounds like this story has been doing the rounds for some time
                                    An Oldbury firm, so quite possible Joh did hear it from soneone who worked there.
                                    Full story is here 1920's by all accounts!
                                      Martin,
                                      For info. Here is a handy reference to Hypodermic Tube sizes.
                                      martin perman 1
                                        @martinperman1
                                        MichaelG,
                                        Thanks for that, interesting data regarding the hole sizes as well.
                                        Martin P
                                        #116294
                                        Geoff Theasby
                                          @geofftheasby
                                          Dave Jones 1, I have read quite a lot about the Rolls Royce company, and although I had heard this and similar stories, I now understand that the American factories were very good at accurate mass production, better than we were in fact. Some aspects of Merlin design were changed to assist the manufacturing process and assembly by less-skilled workers. I hestitate to cast nasturtiums at a wonderful company, whose engineering has always been superb, but truth is better than stories.
                                          Geoff
                                          #116295
                                          Sub Mandrel
                                            @submandrel
                                            That was my thought Geoff,
                                            In a time of war ease of production rules, replacing a precision finishing operation with a stamped gasket is a no-brainer.
                                            Ian S C
                                              @iansc
                                              The difference between a RR Merlin and a Packhard Merlin, RR the oil is on the outside, Packhard, the oil is on the inside, sort of like English and Japanese motor bikes. The American engine had better oil seals, the RR engines had felt seals, I used to have a book with all the modifications that were instituted for mass production.
                                              There was a story in ME proberbly about 20yrs ago about someone who produced a domestic sewing needle drilled lengthwise, there was a bit more to the story, but I can't remember what it was.
                                              As a nurse I'v stuck plenty of needles in people, but I never really thought much about the method of construction. Ian S C
                                              #116308
                                              Grizzly bear
                                                @grizzlybear
                                                Hi Martin, Get a medical diploma and start practicing, the NHS needs all the help it can get.Regards, Bear.. PS: Problems typing this..
