Diamond Inserts
Diamond Inserts
Home › Forums › Workshop Tools and Tooling › Diamond Inserts
  • #658955
    Vic
      @vic
      I noticed these a couple of years ago, anyone tried them? The ones I’ve seen are for Aluminium alloy etc.
      #21089
      Vic
        @vic
        #658958
        bernard towers
          @bernardtowers37738
          I use ccmt 0602 size on ally/brass and bronze, the finish on ally has to be seen. They work on materials without a ferric content.
          #658960
          Vic
            @vic
            To be clear I’m talking about Polycrystalline Diamond Coated, Not the insert shape.
            PCD Insert
            #658963
            Baz
              @baz89810
              Company I used to work for 40+ years ago used to make diamond tooling, we used to machine eight inch diameter ally on a lathe, cannot remember the make, with an air bearing spindle and the finish was a true mirror finish, for about one minute until the ally started oxidising. Vic be careful if you use them on a hobby lathe, you will not have the speed or rigidity and the slightest bit of chatter will most probably chip the insert. If you do mess one up all is not lost, you can still use it to dress your grinding wheels !
              #658967
                I seen several of the model aero engine builders mention them as being able to take off extremely fine cuts which make them ideal for sizing Pistons. Another well respected one says they have transformed the accuracy of his small hobby lathe and he can turn parts for international competition engines with it.
                I keep meaning to put one on an APT order to try out but I've not had a project that reallyneeds them yet.
                #658968
                bernard towers
                  @bernardtowers37738
                  FPerhaps you had better read my post again,just saying what size pcd I use
                  Edited By bernard towers on 03/09/2023 20:25:24
                  Edited By bernard towers on 03/09/2023 20:25:51
                  #658984
                  Emgee
                    @emgee
                    I use PCD in 070202/4 insert size but not the APT version, those I have are from an AliExpress dealer who I have been using for about 2 years, I have the ccmt 0602 size for a boring tool but have not used it yet.
                    The finish is superb and tool life is way beyond that of the GT type inserts on 6082 and 7075 aluminiums, yes very fine cuts can be made such as needed when sizing ringless pistons.
                    Emgee
                    #658993
                    Chris Mate
                      @chrismate31303
                      I got 4 of them, given by another machinist, but have no toolholde for it. He told me I can dress my grinder wheel with it, so I milled and glued one of them into an Aliminium handle I made, and sure as hell I can dress the grinder wheel no problem. In the mean time I got a kennametal book with info on toolholders, but had not got to it to make a toolholder for them with correct geometry. Would be interesting to see how they cut metal.
                      #659000
                        Quick question for those using the PCD, do you use them dry on Aluminium or with some form of lubrication such as paraffin as you might with **GT inserts?
                        #659003
                        Mark Rand
                          @markrand96270
                          Definitely use them dry.
                          I use CBN inserts for turning hardened steel. Lovely surface finish with pretty streamers of red hot swarf flying off the tool. The negative rake on CBN and PCD inserts makes for the good finish, but speed and rigidity are neccessary to get the best out of them. They won't do a lot of good on a white metal bearinged ML7. crying
                          #659004
                            I was thinking about tip build up when working with aluminium which does not tend to be a problem when working steel.
                            #659012
                            Emgee
                              @emgee
                              Posted by JasonB on 04/09/2023 08:16:07:
                              I haven't experienced the same build up problems associated with aluminium when using PCD insert, so far have only used dry, next time i'm using a PCD I will try some fluid on the cut.
                              Still get the bird's nest but it seems to fall away when the tool clears the work, if forming a ball it can be pushed clear with a stick.
                              Emgee
                              #659015
                              bernard towers
                                @bernardtowers37738
                                Jason, I have been using mine dry for about 4years and there is no build up on the tip at all. for hobby use it seems that it has a very long life.
                                #659024
                                Neil Lickfold
                                  @neillickfold44316
                                  I mainly use the DCMT11 size and I really like the Sumitomo ones with all the positive geometry formed into the top of the PCD insert. The smallest radius is 0.2mm and they do 0.4mm as well. Either of the 0.2 or 0.4 mm radius will work.
                                  I only use them for finishing. The simple geometry ones, like in the link, are ok, but are not in the same league as the Sumitomo ones especially when taking very light cuts.
                                  They can be used either dry or with oil or with coolants. When used with IPA or IPA gel, like hand sanitizer, they will also give a great finish.
                                  I always hear that alot of high surface speed or high rpm is needed, and I have found that is not the case at all. Ona 14.6mm diameter, you can get a really good finish at around 600 rpm or so. Cuts can be as small as parts of a micron with patience and a sharp insert.
                                  There are now quite a few different grades of PCD these days, including coated ones. Some work well on the lower silicon Aluminum alloys, and the ones I use are for the high silicon Aluminum alloys . They also work on regular Aluminium as well. I have used then on brass and BeCu at work.
                                  This is what I like here showing the positive geometry. Not cheap, but for certain things it does give a competitive edge.
                                  old mart
                                    @oldmart
                                    I came by about 10 polycrystaline diamond inserts which fit APHT11shell mills in a job lot of inserts. They only have one edge and are intended for machining high silicone aluminium. The got tried out and then stored away and forgotton. Not much use for them in the type of machining we do.
                                    #659721
                                    Vic
                                      @vic
                                      I’m actually quite happy with the polished double sided triangular inserts as you get six cutting tips for your money. I was just intrigued by PCD’s.
                                      Looking at the description on eBay though and one of the suitable materials listed for them was Oak! As I do some wood turning as well this got me wondering. As some of you may know, carbide inserts have become quite popular with wood turners for some jobs. I’ve therefore bought a couple of the type below for £14 on eBay. The actual cutting tip is a bit short for wood turning but they are very sharp. I just need to make a tool holder for them now to try them out.
                                      They were actually listed as VCGT but these say VCMT on the box, anyone know the difference, they look the same? Also the substrate seems to be carbide, is this correct?
                                      #659722
                                        Posted by Vic on 10/09/2023 09:26:18:
                                        The two are identical except the GT has a plain top whilst MT has a chip-breaking edge.
                                        Chips are easier to clear than ribbons by ny experience suggests inserts have to cut fast and deep before the chip-breaker works properly.
                                          Sorry Dave but the M and the G relate to the tolerance that the insert is made to.
                                          Your typical **M* insert will be the moulded gold coloured ones with chipbreaker and "blunt" to the touch
                                          Your Typical **G* insert will have been ground and or polished to get the Tolerance which also results in a sharper cutting edge
                                          As for the T at teh end then that is what indicates if there is a chipbreaker and also how the insert is held.
                                          Typical ***T insert has a has a 40-60deg csk hole and is single sided WITH CHIPBREAKER
                                          Typical triangular Insert you may find on an indexable mill TPUN is neutral or flat topped with no chipbreaker
                                          Edited By JasonB on 10/09/2023 10:11:41
                                          #659732
                                          Vic
                                            @vic
                                            The ones I bought have a slight angle to the tip and being 160402 are quite sharp.
                                            #659739
                                            Neil Lickfold
                                              @neillickfold44316
                                              They are awesome on wood, especially woods that is in the harder range, not meaning hardwoods. They also work well on finishing brass, and most non ferrous materials. I have not used them on copper. But do work really well on Oak, Maple etc. If you get the feedrate right, you won't need to sand what you have turned. They do last alot longer than carbide, assuming you don't chip the insert. Holders are fairly cheap and can be modified to suit your tool holding system.
