Gear cutter definitions.
Home › Forums › Workshop Tools and Tooling › Gear cutter definitions.
  • #19677
    Andrew Tinsley
      @andrewtinsley63637
      #460484
      Andrew Tinsley
        @andrewtinsley63637
        Hello everyone,
        I am sorting out some inherited gear cutters. Most of them have the DP and tooth range stamped on them some also have the Pressure angle too.
        There are quite a few that have simply P stamped on them where I would expect it to be DP. Do I assume that the P is just a shortened form of DP?
        A few have nothing except the manufacturer's number, which I assume are "specials"?
        Thanks,
        Andrew.
        #460492
        Brian H
          @brianh50089
          P could stand for pitch which I would guess would be circular pitch (CP).
          Brian
          #460500
          Andrew Tinsley
            @andrewtinsley63637
            Thanks Brian,
            I had not thought of that.
            Andrew.
            #460637
            Jouke van der Veen
              @joukevanderveen72935
              DP appears to stand for Diametrical Pitch. Number of teeth on a diameter of 1”?
              Jouke
