A Rant to our suppliers of drills
Home › Forums › Workshop Tools and Tooling › A Rant to our suppliers of drills
Viewing 25 posts - 1 through 25 (of 36 total)
  • #368147
    Stewart Hart
      @stewarthart90345
      I know that generally the drills supplied to the model engineering community due to the less demanding use are not of the same quality you will find in industry, but that said they still have to do the job required of them. On two occasions over the last moth I've run into problems resulting in scrap work due to faulty drills. On the first occasion I was using a 3.4mm drill that I'd bought off ebay (yes I know serves me right) the darn thing wouldn't cut on close examination the point was ground with negative rake it was never going to cut it was ok after i'd reground it.
      On the second occasion I used a letter drill bought as part of a set at an exhibition from one of the well known suppliers, I'd not used the drills from the set much, but on this occasion I wanted the part to fit on a odd sized shaft, the darn drill cut over size by about 0.30mm again on inspection the point was ground with uneven lip length a regrind sorted the problem but the part needed remaking.
      To keep the cost down these drills probably came from the far east, but surly by now the buyers know the risk associated buying from this source, so why isn't some sort of receipt inspection carried out on delivery and if they are wrong send them back. I know this would probably push up the cost a little but if it cuts out some of the frustration the increase would be accepted.
      Luckily I have the experience and background to spot what was wrong but I wonder just how many newcomers to the hobby have been driven away because of their struggles with inferior tooling,
      Stew
      Edited By Stewart Hart on 20/08/2018 12:14:48
      #19045
      Stewart Hart
        @stewarthart90345
        #368151
        Tony Pratt 1
          @tonypratt1
          Yes I've had the same problem from a well known supplier, drills looked ok but the lips were not ground correctly, bought in packets of 10 very cheaply, about 4-5 usable, rest need re-grinding.
          Tony
          #368152
          Mike Crossfield
            @mikecrossfield92481
            I can relate to this. A few years back I bought a number of small drills from Axminster, a company I consider reputable. After difficultes getting one to cut I examined it under a glass and found exactly the same problems described by Stew. Negative rake and unequal lips. All the drills I’d bought had the same problems to greater or lesser extent. I contacted Axminister who seemed unable to understand the problem. I suggested they contact their supplier, but they weren’t interested and simply offered a refund (which I declined, having resharpened the drills already). To be fair, the drills were very low cost, but even so one would expect them to cut!
            Since then I have been more selective about what makes I buy, and who I buy from.
            #368154
            Martin Kyte
              @martinkyte99762
              Posted by Stewart Hart on 20/08/2018 12:13:10:
              Stew
              Not entirely sure that applies. OK maybe they get used less often but they should cut cleanly, cut to size and be straight, After all if you are drilling one hole or a 1000 you need the drill to do it's job. No need for us to go off and buy solid carbide drills in the larger sizes but the quality needs to be high if you are drilling at home or at work. The cheap sets are there to protect the engineering sets when you are doing building work or using a battery drill.
              So yes, I agree with you except for your get out clause.
              regards Martin
              #368156
              Thor 🇳🇴
                @thor
                Hi Stew,
                I haven't come across cheap drills with negative rake, but some don't cut a correctly sized hole. I can buy Dormer drills fom a local tool shop (at a premium price) and use them for drilling tapping size holes. The cheap drills are used for drilling in hard steels or when the size of the hole doesn't matter too much, most of the cheap drills usually work Ok.
                Thor
                #368157
                  You can't expect massive-volume low-cost products to be individually checked.
                  "9,877,000 pieces per year" – that's an awful lot to check.
                  The factories will take a sample from each batch, and if its in spec, they will accept the batch otherwise it will be junked (or sold at the factory back door to find its way to you can guess where). You can never expect more than inspection by sample with bulk, cheap drills.
                  Even Dormer or similar will only check on a sample basis – probably a bigger sample and tighter tolerance, but if you want to be assured of quality be prepared pay as much for a single drill as you might for a whole set of cheap ones.
                  Titex use "Statistical Testing"
                  With automated manufacture there will always be ones that get incorrectly set and turn out wrong even with the very best manufacturers. If you buy affordable drills from respectable sellers you will egt teh odd duff one, but at least they will offer refund or replace.
                  fishy-steve
                    @fishy-steve
                    Only last week I was using a 17/64 jobbers drill (clearly marked as such) from a set of drills. This set was purchased from a company who supply to industry.
                    The hole measured .281" !!!
                    After a regrind the hole measured .278" still .013" oversize.
                    I decided to measure the drill and it was .275" or 7mm!!!
                    I've now measured the whole set but all the other drills are OK.
                    Very odd.
                    #368161
                    David Standing 1
                      @davidstanding1
                      Posted by fishy-steve on 20/08/2018 13:13:10:
                      Very odd.
                      For others that may be trying to cross index the three different measurement systems above, 17/64 is .266" wink
                      #368165
                      Martin Kyte
                        @martinkyte99762
                        I can cope with single 'wrong un's' everything thats made has the occasional dud. But to my mind the overall quality needs to be as good as you would expect in any toolroom for general use.
                        Martin
                        #368167
                        Mike Poole
                          @mikepoole82104
                          It may be worth checking cheap drills, I bought some cheapies and some were even bent. I wasn’t too disappointed as at the price I paid my expectations were not high and the odd dud in a pack of 10 can be lived with. Most of my drills are Dormer and I don’t think I have ever had a dud but their price and reputation should ensure satisfaction, I am sure the next post will be from someone who has had a duff Dormer, Ghuring,Titex etc. But despite good quality control a failure will get through.
                          #368170
                          larry phelan 1
                            @larryphelan1
                            I have bought many drills from a supplier called "Drills UK,or UK Drills " [never remember which,grey cells gone rusty ] To date,I have not had any problems with them.No idea where they are made,China,I suppose,but they work. They are not in the same class as Dormer,but neither are they the same price,they seem to be rolled rather than milled,but for workshop use,they,re OK. Good range in Metric and Imperial although I dont recall seeing any number or letter drills on offer.
                            Might be worth a try.indecision
                            #368172
                            Emgee
                              @emgee
                              I do have some boxed sets (1-10 in .1mm increments) of Dormer drills that were bought secondhand from a retired toolmaker, many hadn't even been used, some had been replaced with other top makes so a bargain was had.
                              I do have a very old (40 years) tinned set of Dormer imperial HSS drills but only ever buy single drills now in the size required for a job, always keep with the usual names for best results.
                              Emgee
                              #368177
                                Posted by Mike Poole on 20/08/2018 13:49:49:
                                It may be worth checking cheap drills…
                                +1 to that! I mostly buy and use inexpensive tools and adjust my expectations accordingly. I've got into the habit of checking first before using them on anything important. Generally, I find inexpensive tools are OK rather than impressive but complete rubbish is rare. Doesn't upset me if I find the odd dud. It may be because I avoid very cheap tools and 'bargains', or perhaps I've just been lucky.
                                Jon
                                  @jon
                                  Totally agree Larry for some cheapies that wont get used much or for a one off both them mentioned are alright. Not good just alright.
                                  However theyre in different league to the cheap foreign imports supplied by shop brands.
                                  Having stuff made in asia costs more to return than having them made and shipped, not to mention all the hassle dealing with the problems. Most companys employ full time teams to vet and put right asian imports. Unworthy goods are just passed on, what they gonna do scrap what theyve bought. Wont see many on a certain site or they would get negative feedback!
                                  My advice dont buy tat its cheap for a reason, source proper branded goods from the manufacturer and not some shops brand.
                                  Even then aboves nothing to do with wearability of which theres a whole different world. Base Osbourne, Titex Presto Dormer etc i wont buy, they dont last.
                                  A drill will always measure undersize, assuming have good quality, drill undersize then go through with size and will often be close.
                                  #368183
                                  fishy-steve
                                    @fishy-steve
                                    Posted by David Standing 1 on 20/08/2018 13:30:35:
                                    Very odd.
                                    That made me chuckle. I have an image of everybody frantically flicking through their Zeus charts. 😃
                                    #368184
                                    mechman48
                                      @mechman48
                                      I am guilty too m'lud I have bought assorted drills from various places and found similar faults, negative rake, bowed or bent to the degree that they were unusable, what I did with some was to cut them short before the bowed section & use them as stub drills for general work. I have also found that although some measure undersize they still tend to drill oversize due to some very minor bowing so I tend to drill one size down & check then either finish with correct size or ream, if not too small, I find that this anomaly usually happens with small drills between 1mm > 2.5mm, so in the bin it goes.
                                      Most of my small drills I have bought from 'UK Drills / Drills UK ( usual disclaimer ) in packs of 10' & have found them to be of good quality, with one or two that have to be binned, although a spectacle wearer ( varifocals ) I still can, using a loupe, bring a few back into use for general drilling. The best drills I have used have tended to be 'Guhring' & I believe these are 'rolled' rather than ground, at the end of the day it's still down to 'Caveat Emptor'
                                      George.
                                      #368191
                                      Alan Waddington 2
                                        @alanwaddington2
                                        Heller drills seem good quality for the price….i buy them from my local fastener stockist, but they are widely sold on ebay.
                                        #368204
                                        Alan Jackson
                                          @alanjackson47790
                                          I always drill first with a small pilot drill then a drill just smaller than the finished size, finally open the hole up with the required size, this avoids any drill point grinding coming into play and avoids oversize holes. I think it is an accepted fact that drills usually cut oversize if the drill point is dictating the cut.
                                          Alan
                                          #368206
                                          Steamer1915
                                            @steamer1915
                                            Can I suggest that Stewart meant to say Negative Clearance instead of negative rake?
                                            Steve.
                                            #368207
                                            I.M. OUTAHERE
                                              @i-m-outahere
                                              I have seen new drills ( R/H ) that looked like they were sharpened on a machine designed for sharpening L/H drills !
                                              That reminds me i have to set up my t&c and sharpen a lot of drills – dred !
                                              #368209
                                              Cornish Jack
                                                @cornishjack
                                                This is the product of trying to drill a hole in work-hardened steel with a Fobco Star – the 'thinned' point being produced by thermal distortion and the shape by crap manufacture!!
                                                Rgds
                                                Bill
                                                #368210
                                                David Standing 1
                                                  @davidstanding1
                                                  Posted by fishy-steve on 20/08/2018 15:35:22:
                                                  Very odd.
                                                  Hah, you did it deliberately then wink 2
                                                  #368213
                                                  David Standing 1
                                                    @davidstanding1
                                                    Pretty much all of my drills are bought secondhand as job lots off eBay.
                                                    Yes, you get some junk amongst them, but I mainly get lucky and only buy the quality stuff, old Dormer (pre Brazil), Guehring, Balfour, Sherwood, SKF, Easicut, Presto etc.
                                                    You invariably get duplicates, but I have made up a number of full sets of metric, fractions, number and letter drills in stands, and have lots of spares.
                                                    They invariably work out a fraction (pardon pun) of the cost of new ones.
                                                    #368221
                                                    Trevor Crossman 1
                                                      @trevorcrossman1
                                                      Posted by Cornish Jack on 20/08/2018 18:28:11:
                                                      Rgds
                                                      Bill
                                                      THAT looks more like an old fashioned stick of liquorice rather than a drill. I have broken many drills over the decades, but have never been able to bend one that much !!
                                                      Trevor.
