Hoffman Universal Dividing Head – helical drive shaft seized
Home › Forums › Workshop Tools and Tooling › Hoffman Universal Dividing Head – helical drive shaft seized
  • #335597
    Adam Harris
      @adamharris13683
      I have an old Hoffman Universal Dividing Head (the small 100mm one) with the extra gear shaft extending to the left for helical milling and differential indexing. This shaft seems seized solid and does not engage or interfere with the operation of of the main handle/worm screw movement when indexing. Am I missing some procedure for engaging it? Or is this due to a common point of failure that can be addressed upon dismantling?
      Edited By Adam Harris on 06/01/2018 15:11:36
      #18797
      Adam Harris
        @adamharris13683
        #335600
        Tony Pratt 1
          @tonypratt1
          From memory you need to undo the black plastic ring that clamps the division plate, turning the plate will turn the shaft.
          Tony
          #335602
          Adam Harris
            @adamharris13683
            So I swivel around the outer casing that encases the dividing plates? Hmmm that makes some sense as there is a notch in it and a clamping screw (mine is brass not plastic). I will check it out and revert . Thanks . I wonder why they had an engagement process whereas the "standard" Victoria/Elliott saw fit to have it permanently engaged?
            #335608
            Adam Harris
              @adamharris13683
              no that does not relate
              #335610
                The Victoria/Elliott has a little plunger pin that engages the dividing plate but that means the plate can only be in one orientation as the (as supplied) plates only have one such hole. The K&T has a brass clamp ring which enables the plate to be held in any position and the aux shaft can have a small handle attached for rotating the plate and hence work for alignment prior to locking and plain dividing. Sounds like your Hoffman is the same as this.
                #335616
                Tony Pratt 1
                  @tonypratt1
                  If you release the division plate so it can rotate & then turn it the shaft will then turn.
                  Tony
                  #335619
                  Adam Harris
                    @adamharris13683
                    All sorted! – Good old fashioned seizure – rust, gunk etc.. Thanks anyway Tony for your attempt at help
                    #335622
                    Adam Harris
                      @adamharris13683
                      Thanks Bazyle – discovered Hofmann helical shaft is indeed permanently engaged by bevel gear with dividing plate mounting (bevel gear at back) , just rusted and seized. Plenty of WD40, working back and forth, and now hydraulic oil and all running smoothly
