Sieg SX1L on steroids
Home › Forums › Workshop Tools and Tooling › Sieg SX1L on steroids
  • #301789
    John Rudd
      @johnrudd16576
      #18544
      John Rudd
        @johnrudd16576
        #301790
        MW
          @mw27036
          Very similar to my WM16, although I kept the gears rather than switch to belts and the motor is mounted on a much simpler angle bracket and plate configuration! TEC motors if i'm not mistaken. I call mine the frankenwarco.
          Michael W
          Edited By Michael-w on 09/06/2017 13:09:57
          #301796
            Posted by Michael-w on 09/06/2017 13:08:08:
            Michael W
            So why haven't you sent me a short write up, you know I love covering frankentools in MEW!
            Ian P
              @ianp
              belt drive -1.jpgThese pictures are of a Clarke CMD10 that I converted to belt drive. I started with the standard motor but then decided that the motor would be better if it counterbalanced the head weight if it was at the rear of the column.
              In stages I changed a few other things, moved the Z feedscrew nearer the dovetail, fitted a ex computer tape motor, (later a1Kw servomotor), polyvee belt, converted spindle to a proper quill. It not in use at the minute because I have another mill with longer table travel but l miss its belt drive quietness and smoothness.
              #301885
              MW
                @mw27036
                Posted by Neil Wyatt on 09/06/2017 14:30:17:
                Michael W
                Well I guess I better get to it then !yes
                Michael W
                #658393
                Matthew Corner
                  @matthewcorner42542
                  looks like it would chew some metal!
