epoxy resin preventing from sticking.
Home › Forums › Workshop Techniques › epoxy resin preventing from sticking.
  • #490641
    speelwerk
      @speelwerk
      Would a silicone spray prevent a metal (silver) hinge from sticking to a casting epoxy resin, or should I use something else? Niko.
      #16186
      speelwerk
        @speelwerk
        #490646
        Brian Sweeting 2
          @briansweeting2
          There are a few things available..
          Read here…
          Non stick epoxy
          #490661
          Jeff Dayman
            @jeffdayman43397
            Silicone may interfere wit the curing of the epoxy. Paraffin wax (solid at room temperature) as used for candles and home canning can be used as a "mould release" coating, and will not interfere with the epoxy cure, or bleed out of the hinge later!
            If you melt some wax in a tin over a pan of hot water and dip / air cool the hinge twice you will get a thin but complete coating. Good luck with it!
            #490671
            Old School
              @oldschool
              PVA mould release just paint on a couple of coats.
              #490674
              Joseph Noci 1
                @josephnoci1
                Posted by Old School on 15/08/2020 06:23:54:
                Second that – works a treat – just comes in inconveniently large quantities ( 25liters) in my part of the world!
                Any carnauba based wax works very well – used as epoxy lamination release on molds the world over..wipe it on, let it almost dry and buff it a bit – do a second coat and thats it.
                If you can get hold of Meguiars Mirror Glaze wax – that would be perfect.
                Joe
                #490681
                Brian Oldford
                  @brianoldford70365
                  *1 for Meguiars Mirror Glaze 8 mould release. Great stuff!
                  #490683
                  Clive Brown 1
                    @clivebrown1
                    Where suitable,I've used brown parcel tape, the very thin stuff, as "non-stick" for resins. Works well, one big advantage being that there's usually a roll of it conveniently available in the house.
                    #490695
                    speelwerk
                      @speelwerk
                      Thanks all! Lots of possibilities, I like the paraffin one. Niko.
                      Edited By speelwerk on 15/08/2020 10:02:26
                      #490737
                      Jager
                        @jager
                        I use DEVCON for bedding rifle actions into stocks. In order to ensure that I can get the two items apart after curing I first wipe the barreled action down with alcohol then brush all over with boot polish, leave 5 mins to harden, polish off and repeat. Never had a problem seperating two very expensive items.
                      Home › Forums › Workshop Techniques › Topics
