Wiring metropolitan vickers motor to run in reverse?
Home Forums Manual machine tools Wiring metropolitan vickers motor to run in reverse?
  • #590535
    Shaun Belcher
      @shaunbelcher81617
      I've got a bandsaw that had a dead motor and have a spare vickers motor here to swap it with but it turns In the opposite direction.
      Any ideas on how to wire these in reverse?
      I'm pretty sure it's possible but the original cover is missing which would have had the wiring instructions.
      #14508
      Shaun Belcher
        @shaunbelcher81617
        #590536
        Shaun Belcher
          @shaunbelcher81617
          #590537
          Shaun Belcher
            @shaunbelcher81617
            I also forgot add that there is no capacitor on this motor like is sometimes seen on these.
            #590538
            Paul Lousick
              @paullousick59116
              Lots of previous posts about reversing single phase motors.
              Do a search for "reverse" or "reverse motor"
              #590539
              Ady1
                @ady1
                Swap the black and the brown, plug it into an RCD, press the on switch
                #590540
                Shaun Belcher
                  @shaunbelcher81617
                  Posted by Paul Lousick on 19/03/2022 00:17:50:
                  I've been reading several threads, but none make any sense to me. Every motor is different and I have no idea what each terminal goes where without the wiring diagram.
                  #590543
                  Shaun Belcher
                    @shaunbelcher81617
                    Posted by Ady1 on 19/03/2022 00:37:28:
                    Thanks. That worked.
