wheel quartering
wheel quartering
Home › Forums › Locomotives › wheel quartering
  • #173320
    geoff walker 1
      @geoffwalker1
      I'm not far off quartering the wheels on my Rob Roy.
      Whilst I'm ok on the actual process and understand the techniques required I can't get a definitive answer on which side of the locomotive should lead, drivers left or drivers right.
      Does anyone know, does it matter?
      regards geoff
      #1349
      geoff walker 1
        @geoffwalker1
        #173365
        john kennedy 1
          @johnkennedy1
          Can't see that it matters really.The only reason they are offset is so it will self start ?
          I'm sure someone can come up with a better answer,enough of them have been built…
          #173368
          IanT
            @iant
            Hi Geoff,
            Martin Baker published some useful information about this subject here;
            Unfortunately, he didn't seem to have too much information in this respect about the Caledonian Railway (e.g. for a Rob Roy for instance).
            However, right-hand lead seems to have generally been the norm.
            IanT
            #173371
              Right does seem to be more common but my Hudswell Shunter has the left leading – and I have the photos to prove it's correct to the rivet counters!
              #173377
              Russell Eberhardt
                @russelleberhardt48058
                In his book "Manual of Model Steam Locomotive Construction" the designer, Martin Evans, states that it is normal practice to have the right hand side leading. So I guess that would be what he intended for Rob Roy.
                Russell.
                #173439
                geoff walker 1
                  @geoffwalker1
                  Hi gents,
                  many thanks for all your responses, ( the link is of real interest )
                  looks like I will go with the right hand side
                  regards geoff
