If I overtighten is there not a chance of distorting the bushes ?
There's more chance of cracking the headstock housing on the opposite side if you overtighten
Cast iron is good at compression (squishing) cast iron is bad at tensioning (bending)
So never make it "tight", just nip it up
You have the simplest system, the squish-it-down system
Sounds like you need to source new headstock bearings
Zyto lathes
Edited By Ady1 on 05/11/2018 10:34:20
