Hi All
Cutting Perspex with a very small cutter so needed to do 5 cuts at increasing depths machine is run from GRBL so started of with Z-.006 then added .020 to each run so next run would be at Z-.026,.046,.066,.086, .106 nothing magic there except the bugger would do the-.006 then jump to .086 that broke the tool
So started again Z up off the work same thing kept missing -.126 too -..066
Only way I managed to fix was to replace all the 6 with 5 then worked fine like to know the problem
Cheers
