Y Axis DRO problem
Y Axis DRO problem
Home Forums General Questions Y Axis DRO problem
  • #330946
    petro1head
      @petro1head
      I have a Warco Mill with theiur X, Y and Z DRO
      The Y axis DRO is playing up. It did this once before and it was just a case of switching the DRO off and then on again.
      I suspect its faulty or not been fitted correctly causing it to be damamged over time. I need to check but think its still in warranty
      Any idea or should I just ring Warco?
      Edited By petro1head on 07/12/2017 19:31:57
      #25686
      petro1head
        @petro1head
        #330947
          They can do that when the read head is not quite on one increment or the next, just move the table a fraction and it should stop
          #330954
          nigel jones 5
            @nigeljones5
            Theres nothing wrong with your DRO…mine sometimes does exactly the same and as Jason states, it is between increments.
            #330961
            petro1head
              @petro1head
              Not sure I understand
              I was moving the table at least 3 inches
              #330962
                In that case you have a problem, thought the table was stationary
                Try swaping the wires between the X and Y scales as that should how if the problem is in the scale or the readout.
                #330980
                petro1head
                  @petro1head
                  Done that and still the Y scale not reading properly
                  I will email Warco
                  Thanks
                  #331003
                  I.M. OUTAHERE
                    @i-m-outahere
                    Hopefully it is still under warranty and they should replace it .
                    At least you know it is not the scales so an easy change over .
                    I read somewhere , maybe another forum of a fault with the display where it had to be reset on power up which it should never have to so maybe a proliferationation of dodgy displays coming out of china ?
                    #331029
                    petro1head
                      @petro1head
                      Posted by XD 351 on 08/12/2017 04:30:22:
                      I think you missunderstood. The display is fine, its the scale thats faulty
                      #331040
                      Nick Hulme
                        @nickhulme30114
                        Have you checked that the read head is correctly positioned relative to the scale?
                        There isn't a great deal of margin for error. I had a similar thing happen when a mounting bolt on which I had not used locking compound allowed the read head to slip slightly out of position.
                        #331072
                        Dave Halford
                          @davehalford22513
                          Could be coolant or dust got in the scale, does the seal strip work properly?
                          #331073
                          petro1head
                            @petro1head
                            Nothing inside, clean.
                            Warco have agree the unit is faulty and they will replace it
                            However their site is showing out of stock for the 250mm scale. I wonder if a 300mm one will fit?
