X Axis power feed on Emco copy using a wiper motor
Home › Forums › Work In Progress and completed items › X Axis power feed on Emco copy using a wiper motor
  • #276339
    petro1head
      @petro1head
      Just finished the first part on my X Axis power feed for my mill, Next task will be the PWM and finding a suitable power supply, any suggestions?
      Edited By petro1head on 07/01/2017 15:44:15
      #31146
      petro1head
        @petro1head
        #276342
        Stuart Bridger
          @stuartbridger82290
          Nice work!
          #276345
          John Haine
            @johnhaine32865
            There have been a couple of threads here on power supplies and speed controls for fine feed. A quick approach is to go to your local Maplin's and buy an MFA speed controller and a suitable 12V supply – look at them online.
            #276346
            ianj
              @ians
              Looks very good,
              What make/model is the vice on the milling table? How do rate it?
              Ian
              #276347
              petro1head
                @petro1head
                Posted by ian j on 07/01/2017 16:27:34:
                Looks very good,
                Ian
                I think I got it from Warco. Its 75mm jaw and opens about 70mm. To be honest it does not open wide enough for me so may be looking to replace it with this – http://www.chronos.ltd.uk/cgi-bin/sh000001.pl?WD=vice&PN=Engineering_Menu_TWV_Swivel_Milling_Vices_93%2ehtml#a110012
                Edited By petro1head on 07/01/2017 16:51:03
                #276353
                Ajohnw
                  @ajohnw51620
                  Posted by petro1head on 07/01/2017 16:43:30:
                  Looks very good,
                  Ian
                  I think I got it from Warco. Its 75mm jaw and opens about 70mm. To be honest it does not open wide enough for me so may be looking to replace it with this – **LINK**
                  Personally I would look at the similar ones that can be used on or off the swivel base to give max headroom when the swivel isn't needed.
                  If I thought you could collect from B'ham I'd also mention that I have one virtually unused that I want to sell at some point. I think Arc do them too. There are several ways of holding things on some of them.
                  peak4
                    @peak4
                    It's rather nearer than the prototype lashup I did for power cross feed for my Myford S7.
                    That is still in use as I never did get round to making it permanent, but as a "Temporary" power supply I used a transformer box, with built in rehostat, originally designed for model railway use. I think mine's a Hornby, but its in the other workshop at the moment. To be fair, the motor is smaller than your wiper motor off a car, so I'd suggest measuring the current draw on yours first.
                    The other thought I had, when it came to developing the design for the Dore-Westbury Mill, was to incorporate a 12v clutch from a car air conditioning compressor.
                    Edited By peak4 on 07/01/2017 17:50:23
                    #276364
                    martin perman 1
                      @martinperman1
                      Nice to see somebody getting something done that I have wanted to do for years, I've had the parts around me for ages but as ever I never seem to get around to it.
                      Martin P
                      #276365
                      petro1head
                        @petro1head
                        Posted by Ajohnw on 07/01/2017 17:27:35:
                        Looks very good,
                        Ian
                        Like this? **LINK**
                        Actually the one I lined to can also be used without the swivel base as I have the smaller version
                        Edited By petro1head on 07/01/2017 18:01:53
                        #276369
                        petro1head
                          @petro1head
                          Posted by martin perman on 07/01/2017 17:51:05:
                          Martin P
                          Thanks, I am also considering doing the same to the Z axis
                          #276373
                          martin perman 1
                            @martinperman1
                            Z as in vertical or crosswise, either would be interesting as you would still need to retain a manual function, or not.
                            Martin P
                            #276999
                            petro1head
                              @petro1head
                              Now completed the project, here is part 2
