Worth Rescuing?
Worth Rescuing?
Home › Forums › General Questions › Worth Rescuing?
  • #301661
    Barnaby Wilde
      @barnabywilde70941
      Anyone ID what this roller is used for. It’s in good condition but seized.
      IMG_20170608_071539366
      free pic hosting site
      Edited By Mick Charity on 08/06/2017 12:02:48
      #25291
      Barnaby Wilde
        @barnabywilde70941
        #301663
        Martin Kyte
          @martinkyte99762
          The closest I could go would be to put the set in a large bandsaw blade but you would never get a closed loop in or out. The top roller does not seem to be de-mountable ( is that a word). Maybe conveyer belt belting to generate a cupped bias.?
          regards Martin
          Edited By Martin Kyte on 08/06/2017 12:16:10
          #301664
          Bob Stevenson
            @bobstevenson13909
            The only time/place I hae seen anything like that was at the Boosey & Hawkes factory where they used a very similar tool to carry out the initial shaping on the blanks for brass musical instrument bell sections,……..the flat sheet is cut out along a template and the 'blank' passed thru the rollers to impart a curved channel section. The edges are then closed and brazed and then wooden formers are used to quite litterally 'bash' to the final shape.
            #301666
            roy entwistle
              @royentwistle24699
              Could possibly be for a saddler
              #301667
              Barnaby Wilde
                @barnabywilde70941
                Top roller is iron. Bottom looks to be ally but poss either copper plated . . . or used to roll copper. I’m stumped. No makers name anywhere.
                #301669
                not done it yet
                  @notdoneityet
                  First thought that came to my head was a roller to shape roofing valleys. Likely a million miles off the real use!
                  #301670
                  Ian S C
                    @iansc
                    "Snap", this is sitting outside my mates museum about a hundred meters from where I live, its for rolling leather.
                    Ian S C
                    Edited By Ian S C on 08/06/2017 13:08:17
                    #301674
                    Hopper
                      @hopper
                      Wow, what are the chances of that???
                      What exactly would one make out of rolled leather? I always thought of leather as flexible enough to curve by hand. Obviously I'm wrong but just wondering how it all works.
                      #301676
                      Ady1
                        @ady1
                        Looks like a proper antique tool, well worth saving in my book.
                        I use colloidal graphite to free stuff up, others in here also have decent alternative systems
                        #301680
                        Martin Kyte
                          @martinkyte99762
                          I find rhubarb is pretty effective for loosening things up.
                          :0)
                          #301687
                          Vic
                            @vic
                            Posted by Ian S C on 08/06/2017 13:01:43:
                            Ian S C
                            For what purpose?
                            #301688
                            MW
                              @mw27036
                              Hide when turned into leather through tanning is much thicker before its rolled scraped or stretched to size. So its part of the making process
                              Edited By Michael-w on 08/06/2017 15:26:58
                              #301689
                              John Flack
                                @johnflack59079
                                Martin Kyte…….doubly so if you have a raphanus allergy😱😱😱😱
                                #301696
                                Barnaby Wilde
                                  @barnabywilde70941
                                  Ian S C
                                  Cheers. I knew you lot wouldn't fail.
                                  I'm not interested in it myself but I've asked them to put it to one side for a few weeks in case anyone does. I can't see it being much value in a 'man cave' or shabby chic setting but there has to be someone out there that could find a new home for it.
                                  It's located at the Household Waste & Recycling site in Darley Dale nr Matlock Derby's.
                                  #301699
                                  Martin King 2
                                    @martinking2
                                    Leather is often worked or rolled wet and takes a 'set' and becomes hard when dried out. Bit like me…..
                                    Martin
                                    #301738
                                    Chris Evans 6
                                      @chrisevans6
                                      Walsall Leather Museum may have something similar.
                                      #301743
                                      Robin Graham
                                        @robingraham42208
                                        I'd have that to restore Mick, if they're not asking much more than scrap for it – time has gone when you could turn up at the tip and take stuff away for free. No particular need to roll leather, but it looks too nice a bit of machinery to be consigned to the furnace. Any idea what they want? I'm in Matlock area too.
                                        Rob
                                        #301748
                                        Barnaby Wilde
                                          @barnabywilde70941
                                          Posted by Robin Graham on 08/06/2017 22:09:56:
                                          Rob
                                          Pop down & ask 'em.
                                          It's been put to one side but it'll get chucked in a bin or end up with a dealer eventually.
                                          They have no idea what it was used for & I reckon negotiations should start at £10. It really does look like a nice bit of kit, obviously manufactured but no makers mark anywhere.
                                          #301781
                                          Ian S C
                                            @iansc
                                            No makers mark here either, had a look at Google last night, and about all I could get was roller skates, but I'm sure there is something on line that I identified it a couple of years ago.
                                            Ian S C
