WORDEN CUTTER GRINDER
Home › Forums › General Questions › WORDEN CUTTER GRINDER
  • #657392
    Douglas Johnston
      @douglasjohnston98463
      I am in the process of clearing out my workshop and unearthed a partly built Worden cutter grinder that has been lurking in a dusty corner for many years. While I am still able I thought I would finish the construction but I notice that the metal plinth that the motor sits on is missing. Can someone who has a Worden please give me the dimensions of the plinth so I can fabricate a replacement. It is the height of the plinth that is my main concern, the length and width don't matter so much.
      Doug
      #29339
      Douglas Johnston
        Height of motor plinth
        #657396
        David Noble
          @davidnoble71990
          Hello Doug,
          If someone doesn't reply sooner, I'll find the plans tomorrow and send a photo.
          David
          #657398
          Nigel Graham 2
            @nigelgraham2
            It's 3 inches on my Worden, but NB this is a Hemingway Kits machine so may differ in details from the original.
            (The plinth is supplied ready-folded in the kit.)
            #657415
            Howard Lewis
              @howardlewis46836
              Just measured mine. My kit was bought at least 30 years ago, so pre Bridgenorth days.
              The plinth for the motor is 3" high
              Width 4 15/16"
              Lrength 6 15/16" with a 1" wide flange along each side, for the M6 setscrews that pass through into the tappings in the bars that reinforce the base
              On mine, the capacitor was a shade too long to fit into the box, so the rear face had to be bored to let the plain end of the capacitor protrude.
              HTH
              Howard.
              #657455
              Douglas Johnston
                I have the plans David but the dimensions are not given since the plinth was supplied already folded up. Thank you Nigel and Howard for supplying the dimensions I was looking for, much appreciated.
                Doug
