wood working
wood working
Home Forums Beginners questions wood working
  • #813387
    Danni Burns
      @danniburns84841
      Hi all
      Is this forum for just metal works? Or carpentry also?
      I need some oak strips/beading – I’m not in the trade and don’t know where ro get this without getting ripped off. Cheers
      bernard towers
        @bernardtowers37738
        depends what and how long its not too bad to make pieces about 2 foot long if you make a planing box I made all my timber strips and cladding for my living van (2 inch) like that and the timber comes out within a few thou of the intended size. You need a good lack plane with a VERY SHARP blade.
        #813403
        Mark Easingwood
          @markeasingwood33578
          Depends what sizes you are looking for, and where in the country you are based.
          Local Timber merchant, independent DIY shop, or Joinery/Kitchen manufacturer would be a good choice. Builders Merchants and large chain DIY shed not such a good choice.
          If it is just a few small bits that will fit in an envelope, or if you are near East Yorkshire, then I may be able to help, as Joinery Manufacture is my job.
          (If you call it Engineered Wood, then no one can complain, that you have dared to mention the, “Brown Stuff” !!!)
          Mark.
          #813405
          Danni Burns
            @danniburns84841
            Hi. I dont have the tools or materials.
            then.
            I need the following (can provide drawing)
            i) tapered beading 10mm (tapered to 5mm) x 23mm (6qty x 1100mm)
            ii) strips 6mm x 10mm (6qty x 1100mm)
            Any ideas?
            dimensions of profile is 23mm x 10mm (slope to 5mm) – like a wedge shape. 1100mm long. I need 6 of these.
            Also I need some
            6mm x 10mm strips.
            #813406
            Bazyle
              @bazyle
              Do you have a Men in Sheds near you? Mostly they do wood rather than metal. Check at
              https://menssheds.org.uk/find-a-shed/
              #813417
                Both these are fairly local to me and will machine to profile and send by courier
                Surrey Timbers
                South London Hardwoods
