Wm180 change gears
Wm180 change gears
  • #33687
    Bernard Reilly
      @bernardreilly64467
      #497184
      Bernard Reilly
        @bernardreilly64467
        Hi can any WM180 lathe owner enlighten me as to the change wheel tooth form profile for this machine. Warco could not supply this information. I intend to manufacture a set of change wheels in Delrin for the leadscrew feed unit only. I require 5 off 20.24,72,80 x 2. Manufacture is not a problem however I do need to know what involute cutter to purchase.
        Thank you Bernard Reilly by Glasgow.
        #497190
        Niels Abildgaard
          @nielsabildgaard33719
          In a thread here called lathe improvements a russian citizen of London calling himself (You_engraving/Ebay) made some for my WM180.
          Very fast , cheap and working well .
          They are module 1 with 20 degree pressure angle as I remember.
          Out of interest,why do You need 5 sets?
          #497192
          Tony Pratt 1
            @tonypratt1
            It's bound to be 20 degrees PA.
            Tony
            #497207
              Should be easy enough to measure one of the other gears to confirm the size which will be Module and 20degPA
