WM180 Chage Gears
WM180 Chage Gears
Home › Forums › Manual machine tools › WM180 Chage Gears
  • #185678
    David Cambridge
      @davidcambridge45658
      Hello All
      Yesterday I had my first go at screw cutting on my Warco WM180 lathe – it all went rather well and I was pleased with the results. However, this did mean I also had my first go and changing the gears to get the correct pitch and I’m having difficulty putting things back to how they were before I started. I’ve returned the gears to the original ratio, but unlike before the gears now seem quite noisy. Does anyone have any tips ? It’s not excessive, but it’s annoying that I can’t return things to their original state.
      Thanks
      David
      Edited By David Cambridge on 06/04/2015 07:53:36
      #12456
      David Cambridge
        WM180 Chage Gears
        #185680
          Could be badly meshed gears. If you cut some copy paper into thin strips bed this into the mating gear teeth as you assemble them onto the banjo which will give about the right clearance. Just work the gears back & forth buy hand and feed in the strip, it will look like a concetina.
          The other thing that can cause problems are the washers that space the gears off the banjo, they are slightly different thicknesses and if mixed up you can get the sides of the gears rubbing each other.
          #185709
          David Cambridge
            Thanks Jason – putting the paper between the gears worked a treat!
            David
