WM18 Earth Fault – Looks like Controller blew
Home › Forums › Workshop Tools and Tooling › WM18 Earth Fault – Looks like Controller blew
  • #366834
    Ross Lloyd 1
      @rosslloyd1
      Hi
      Just wondering if anyone else has come across this? Ive had the mill only a few months (WM18 from Warco) and from the start it had a bit of a strange tendency to 'hunt', with sudden spikes in speed generally when you first turned it on and began to dial up to machining speed. I let it go for whatever reason.
      I started it up today to do some drilling, and all of a sudden the effect was much worse, speed jumping up then down. It did this three times and then all the lights went out and the mill went off. It had tripped the earth leakage fault protection back in the house.
      Now the mill does not work at all. The box powers up, I can hear the transformer running. I have checked all three fuses (plug and the two in the base of the control box), the blue light up display illuminates and the LCD works. The spindle and gearbox all turn freely.
      After measuring with a multimeter, there is zero voltage on the motor (you can access the screw terminals to the brushes by taking a cover off) even with power on and rpms turned up, so it looks like something has shorted to earth inside the controller, given that it was the earth leakage trip that went and none of the other fuses blew in the mill.
      Ahead of contacting Warco on Monday, any clues as to what might have gone and likely resolution? The mill is well within warranty. Do warco just send a new part or does someone come out to fix it?
      Cheers
      Ross
      #19036
      Ross Lloyd 1
        @rosslloyd1
        #366838
        Nige
          @nige81730
          Likely blown one or more of the large three legged switching devices on the main control board. I would be very surprised if Warco would send someone out to fix it, more likely to send you a new board to change out yourself assuming it is still carrying some sort of guarantee.
          If you do have to swap it out yourself take plenty of photos and notes as to what goes where. and unplug from the mains first. Good luck
          #366844
          Ross Lloyd 1
            @rosslloyd1
            Thanks Nige, I thought it might be something along those lines. I am quite happy to replace myself, always good to learn what the insides of any machine are like.
            #366852
              They will probably ask you to send them the board for repair/replacement, so take a few photos to help make sure you can get it back on right.
              John Rudd
                @johnrudd16576
                From your description above, "none of the fuses have blown, and it tripped the earth leakage breaker", suggests to me that the motor is faulty…
                The thyristors or ' three legged devices' have isolated tabs, that means even if they failed short circuit across their junctions, ( anode/cathode…) that would not cause an earth leakage trip….
                The circuit board can be tested in isolation by disconnecting the motor from the board and substituting a 100 watt light bulb, the brightness should vary when the speed pot is turned up and down….
                Testing the motor for leakage to earth will require an insulation tester ( 'megger'….)
                Hopefully Warco will resolve this for you without delay.
                Edited By John Rudd on 11/08/2018 22:04:57
                Edited By John Rudd on 11/08/2018 22:05:24
                #366868
                Ross Lloyd 1
                  @rosslloyd1
                  Hi John
                  If the board was ok, wouldn't you expect to see voltage at the motor terminals? When measuring across the screw terminals there was no voltage at all. As the terminals are connected directly to the controller, I would expect to at least see a voltage across them even if the motor was faulty?
                  Cheers
                  Ross
                  #366871
                  John Haine
                    @johnhaine32865
                    If you have had it only a few months it is THEIR problem, not yours. I would suggest that you are careful not to do anything that dilutes their responsibility for fixing this.
                    #366872
                    John Rudd
                      @johnrudd16576
                      Ross,
                      Oooh my bad…..I missed your statement about there being nothing at the motor terms…,( assuming you had good contact with the wiring and your meter works ok. on dc volts range ..😀 )
                      Have you checked the motor commutator? Does it look burnt/carbon'd up?
                      Bottom line here is the machine is under warranty, so rather than speculate on what is/isnt ….let Warco decide and act accordingly to your satisfaction
                      #366886
                        While you check the commutator take a look at the brushes, when my lathe started running irratically like you describe this was the cause.
                        #366897
                        Ian Hewson
                          @ianhewson99641
                          As it’s under guarantee I would suggest you don’t start playing with it, Warco have a 6 month on site option to use.
                          Dismantling could void your warranty.
                          #366911
                          joe king 2
                            @joeking2
                            Posted by Ian Hewson on 12/08/2018 09:46:56:
                            Could not agree with you more Ian
                            I have never understood why people jeopardise their warranty by dismantling when they do not need to.
                            #366914
                              Posted by joe king 1 on 12/08/2018 11:19:05:
                              It's because these machines have a tendency to minor assembly faults like loose screw terminal connections. As these are easily fixed, it's worth having a look because of the time and trouble saved.
                              I agree though that some go a bit mad and tear the whole machine apart. That's not a good idea. If a machine is under warranty and the supplier can see you've been at it, you went too far.
                              I bet the suppliers of these machines could tell some stories about the occasional unwise customer…
                              Ed Duffner
                                @edduffner79357
                                I had the same problem as Jason a couple of weeks ago, re: carbon brushes on my WM-16 mill which resulted in one of the glass fuses blowing due to over-current.
                                If it's an earth fault I'd look inside the control box to see if there has been a short to earth of some kind from the PCB to the case itself, a bit of loose wire or swarf left over from manufacture perhaps.
                                If possible I'd also check the outputs of the PCB to see if voltage is actually leaving it.
                                Ed.
                                #366930
                                Former Member
                                  @formermember19781
                                  #366933
                                  not done it yet
                                    @notdoneityet
                                    Personally, I can’t really undestand why anyone posts on here re in-warranty failures, except to warn others of the frailities of the machine or control electronics.
                                    The first port of call should always be the supplier. Even if a weekend fault. Also, a record of the conversation, or otherwise exchange, should be retained for future use, should it become necessary in the event of further problems.
                                    Unauthorised ‘fiddling around’ is a simple way to void any warranty.
                                    This thread seems to be one of arming the poster with information as to whether the failure is common. How the supplier might approach the warranty claim is entirely up to them and no prior conjecture will alter that.
                                    The replies confirming you should not interfere with it prior to contacting the supplier are likely the best replies you have or are likely to get.
                                    It would seem that you have had, for whatever reason, a fault which was apparent earlier, but you failed to inform the supplier – until it has escalated tonthe point of complete machine stoppage. Not good for either party.
                                    #367182
                                    Ross Lloyd 1
                                      @rosslloyd1
                                      Hi chaps, just an update. Spoke to warco today and they are sending out a replacement board tomorrow first thing It falls to the customer to replace 'simple' components like boards, so I have removed the board ahead of it arriving. Warco said I could keep the old one. If that doesn't work they will send someone out.
                                      Here's the culprit. Looks like a few factory attempts at drilling went awry, and the swarf embedded itself in and made its way through the insulating tape (I checked and the tape is not electrically conductive, though may be thermally so. Top pic shows the mosfets in situ on left, note the insulating grommets keeping the bolts from touching the mosfet tab. Bottom shows the worn-through tape and chewed up drill holes after removing.
                                      NOTE: Warco suggested I open the box to remove the board and said I could dispose of it.
                                      May be worth checking if you own this or similar mill, especially if you don't have an RCD capable of tripping on earth leakage.
                                      #367191
                                        Posted by Ross Lloyd 1 on 13/08/2018 20:32:46:
                                        Thanks for sharing that, Ross … it speaks volumes.
                                          Thanks Ross – most interesting. Just goes to show how a small fault in the wrong place can cause chaos. Attention to detail is important. They build an entire milling machine and then a silly factory mistake spoils it.
                                          The 'tape' is a silicon thermal conductor and electrical insulator. It needs to be fitted! Not difficult to source. More or less anyone who sells semiconductors – Farnell, amazon etc. Try searching for 'Heatsink insulator pads' or transistor insulator etc.
                                          john swift 1
                                            @johnswift1
                                            as the fault was swarf shorting the semiconductors metal tab to the heatsink
                                            it looks like the speed control is a copy of KB electronics KBLC-240D (or some thing similar )
                                            KB electronics use devices that have isolated TAB's on the 3 diodes & 2 thyristors ( forming a controlled bridge rectifier ) & does not require the insulator
                                            the copies use cheaper devices that don't have isolated TAB's and there for requires the insulator
                                            john
                                            Edited By john swift 1 on 13/08/2018 21:32:13
                                            #367200
                                            Ross Lloyd 1
                                              @rosslloyd1
                                              Posted by SillyOldDuffer on 13/08/2018 21:19:14:
                                              Many thanks Dave, I will add that to the shopping list!
                                              Cheers
                                              Ross
                                              #367203
                                              Ross Lloyd 1
                                                @rosslloyd1
                                                Posted by john swift 1 on 13/08/2018 21:24:11:….
                                                john
                                                Interesting info, thank you for sharing it. The board number in the Wm18 is JD-014, which appears to be the same one used by the grizzlys.
                                                EDIT: Thats what's on the board at least. A sticker on the heat sink mounting plate reads "DC MOTOR SPEED CONTROL – Model: JYMC-220B-I"
                                                Edited By Ross Lloyd 1 on 13/08/2018 21:48:23
                                                #367313
                                                Ross Lloyd 1
                                                  @rosslloyd1
                                                  Have shown the pictures to an electrical engineer friend and when I mentioned the 180V likely to be in those tabs, he pointed out that the "swarf" may actually be tracking damage as the fault moved through the aluminium backing. The initiator then may have been the misaligned rubber strip, which was placed too low on the two thyristors. The plastic shoulder that insulates the screw from the tab had also partially melted.
                                                  #368763
                                                  Ross Lloyd 1
                                                    @rosslloyd1
                                                    Mill is finally fixed! Looks like it was a dodgy board, that somehow also cooked the main control pot that has a good 120VDC running through it. When I replaced the board the first time, something went bang presumably due to the now dodgy pot, leaving some choice scorch marks on the new board.
                                                    Warco kindly sent out a very helpful gent who changed the pot and the board, and the mill is now performing better than it did when new.
