Windows 10 forced upgrade
Home Forums General Questions Windows 10 forced upgrade
Viewing 25 posts - 151 through 175 (of 198 total)
  • #248274
    NJH
      @njh
      Mark – look HERE
      My wife has it on her pc – works OK – she upgraded from Win 8.
      I had Win 7 but have since ( due to constant harassment from my kids and grandkids) converted to Apple !
      Norman
      Edited By NJH on 27/07/2016 14:29:24
      Vic
        @vic
        Posted by NJH on 27/07/2016 14:28:28:
        Norman
        Good Man, you know it makes sense! wink
        #248317
        Sandgrounder
          @sandgrounder
          Posted by Mark P. on 27/07/2016 14:14:06:
          What has W10 got to offer over W7?
          Mark P.
          Support, I believe Microsoft ended mainstream support for W7 last year and will end extended support in 2020 so you are becoming more vulnerable to attack.
          Anthony Knights
            @anthonyknights16741
            You don't suffer attacks if you don't go on line with unsupported versions of windows, I use several older versions of windows to run various programs, but use Linux to go on line. It can be slightly inconvenient if I need to transfer downloads, but memory sticks (aka thumb drives) are wonderful things.
            #248323
            Sandgrounder
              @sandgrounder
              Posted by Anthony Knights on 28/07/2016 07:58:26:
              That's almost exactly what I do, I have an old XP machine which runs Autocad and Inventor and is never connected to the internet, 99.9% of my internet use is on my Linux PC which I've had for 3 years, but for the odd program which needs Windows such as my Garmin map updates I have bought a second hand W10 laptop which runs fine, I've never had Vista, W7 or W8.
              Enough!
                @enough
                Contrary to common belief, security updates are still available for XP. Apart from that, I still have an XP machine (or two) that are set up for special purposes which I use to go on line sometimes without feeling paranoid about it. I take the usual reasonable precautions (flash, java, javascript only on demand; a healthily large hosts file etc) which I take on all my machines regardless of OS. Apart from that, the XP installations are sufficiently unchanging that I can have a full image backup of the installation including the apps I want. If it did get compromised I'd just restore one of those. Hasn't happened yet.
                I don't mess around with usb drives or linux. The XP machines are hooked into my LAN so any data is accessible.
                #248369
                Vic
                  @vic
                  I've never actually liked any version of Windows but must say that XP was the most productive version I've used. Luckily I'm retired now so don't have to use any of Microsofts stuff. wink
                  #248371
                  Sandgrounder
                    @sandgrounder
                    Posted by Bandersnatch on 28/07/2016 15:09:06:
                    I don't think you'll find many people mess around with Linux, they use it because they think it's better than Windows.
                    Vic
                      @vic
                      I got the impression that folks liked Linux because it was faster than Windows and less likely to be attacked by malware and viruses etc?
                      #248376
                        Mark P.
                        "cryptoviral ransomeware"
                        #248377
                        duncan webster 1
                          @duncanwebster1
                          The idea of not being able to turn Cortana off has finally decided me. Mr Gates can keep his free upgrade, and when he stops supporting W7 I'll go to Linux on anything that connects to the web. I'm already running it on my laptop and it seems fine
                          #248380
                          roy entwistle
                            @royentwistle24699
                            Duncan I have turned Cortana off No problem  I've had one or two hang ups but a restart has cured that
                            Roy
                            Edited By roy entwistle on 28/07/2016 18:19:54
                            #248381
                            Enough!
                              @enough
                              Posted by Sandgrounder on 28/07/2016 16:48:03:
                              I'm not particularly against (or for) Linux. It's the stoopid "my OS is better than your OS" knee-jerk stuff that keeps arising here and elsewhere that I find tedious.
                              #248383
                              Enough!
                                @enough
                                Posted by duncan webster on 28/07/2016 17:59:40:
                                Duncan, go here and it will tell you how to turn off Cortana plus a whole bunch of other stuff that you really don't want.
                                #248390
                                  I haven't switched Cortana on, but it seems easy enough to turn it on and off?
                                  <edit> It's not as though Microsoft make it hard…
                                  Just type 'cortana settings' into search, choose 'cortana settings' from the results and slide the cortana switch to 'off'.
                                  Edited By Neil Wyatt on 28/07/2016 19:39:40
                                  #248393
                                  John Stevenson 1
                                    @johnstevenson1
                                    Isn't a Cortina a bit old hat now ?
                                    Even Neil has got a Mondayo
                                    #248411
                                    duncan webster 1
                                      @duncanwebster1
                                      According to a press report even if you manage to turn it off , every time Mr Gates sends one of his compulsory updates he will turn it back on. I can't be doing with that.
                                      #248413
                                        Posted by duncan webster on 28/07/2016 21:57:56:
                                        Well said, Duncan
                                        That short comment sums up the whole situation as far as I'm concerned.
                                        Enough!
                                          @enough
                                          I think I'll reserve judgement on that. There doesn't seem to be any logic in it to me. It's not something they can sneak in without anyone noticing and all it will do is p**s off everybody who has it turned off. And at what benefit to MS? None that I can see. And it's not a security issue where MS can convince themselves (and try to convince us) that they are protecting us from ourselves and the whole world along with us.
                                          Press reports aren't always the most reliable. It hasn't happened to me yet (on my one rarely used laptop machine that I've upgraded experimentally).
                                          #248457
                                          Farmboy
                                            @farmboy
                                            My experience for what it's worth:
                                            After a year with Windows 10 which I upgraded from 7 there has only been one major version update which reset some of my privacy settings; the routine updates don't generally do so. I only use the basic OS with all the "kids' toys" turned off, and so far it appears to be a very stable system. Any problems have usually turned out to be due to third party software I've installed.
                                            If all I did was browse the web and use basic office software I would most likely switch permanently to Linux, which I also use, but I need to use some programs which are Windows specific.
                                            If you search the internet you can find "facts" to support any prejudice you may have; your own experience is the best guide.
                                            #248480
                                            NJH
                                              @njh
                                              "If you search the internet you can find "facts" to support any prejudice you may have; your own experience is the best guide."
                                              Wise words indeed!
                                              Norman
                                              Edited By NJH on 29/07/2016 10:29:47
                                              #248490
                                              Roger Provins 2
                                                @rogerprovins2
                                                Posted by Farmboy on 29/07/2016 09:05:11:…….If all I did was browse the web and use basic office software I would most likely switch permanently to Linux, which I also use, but I need to use some programs which are Windows specific…..
                                                Been using Linux of various distros for many years. I too have a couple of programs that are unique and I need but are only available written for Windows. I've found that, with a little configuring, they both run satisfactorily either in a DOS or WINE emulator or a Windows Virtual Machine.
                                                Whether it's worth it or not is of course another matter.
                                                #248492
                                                roy entwistle
                                                  @royentwistle24699
                                                  Duncan Cortana has never come back on mine
                                                  Roy
                                                  #248493
                                                  Vic
                                                    @vic
                                                    Duncan Cortana. Who could come up with a name like that! laugh Sorry, I'll get my coat …
                                                    #248497
                                                      Posted by John Stevenson on 28/07/2016 19:56:35:
                                                      When I heard of cortana I thought that's curtains for Microsoft.
                                                      Coming round to duff you up now
