Imperial Bearing Surprise!
Home › Forums › General Questions › Imperial Bearing Surprise!
  • #797170
    Peter_H
      @peter_h
      So, according to my parts manual I need a Hoffmann S9 7/8″id x 1.7/8″od x 3/8″ bearing. Found that KLNJ7/8 is the replacement, ordered a cheapo one from ebay and it arrives with a width of 1/2″ not 3/8″. After a lot of hunting I have found that the KLNJ7/8 replacement part is 3/8″ wide as an open bearing, but 1/2″ wide when it is a -2RS or -ZZ. Never in 50 years of engineering have I seen the same part number used for two different sized parts.
      Does this surprise other people or has this ‘snippet’ just passed me by?
      #797178
      bernard towers
        @bernardtowers37738
        Aernt you changing the part no when you add 2RS or ZZ to it?
        #797242
        Bernard Wright
          @bernardwright25932
          Is the original bearing 3/8″ wide and NO seals.
          If so, surely if you ask for KLNJ7/8, that’s exactly what you should receive..
