Will it be strong enough?
Home › Forums › Beginners questions › Will it be strong enough?
  • #101461
    nigel jones 5
      @nigeljones5
      The last 2 inches of my regulater connecting rod are 5/32 square section. I cant make it any bigger or it will foul the valve link arms. Ive only got steel or brass, cant use steel in boiler (wont last long at that thickness) so question is, will brass be strong enough? I inted to fit travel stops on the regulator arm so it wont be possible to put lots of torque into it, I just dont want it twisting/shearing off!!
      #6395
      nigel jones 5
        @nigeljones5
        #101468
        FMES
          @fmes
          Why not stainless steel?
          #101470
          Steambuff
            @steambuff
            Since it is inside the boiler I would use either Bronze or Stainless Steel. (Copper is the only other material I would use inside a boiler but is not strong enough in this case)
            nigel jones 5
              @nigeljones5
              no one makes stainless in this size!
              #101489
                What length do you need? 4mm stainless keysteel is available but in 300mm lengths.
                Kwil on here was after some a while ago and I put him onto my local Stainless stockholder but I think he may have had to settle on a 3m length of 5mm in the end.
                Can you not mill down the next available size?
                #101492
                mick
                  @mick65121
                  Why not use free cutting Bronze, have a word with Viv at Milton Keynes Metals
                  #101493
                    Just another though what about silver soldering square ends onto a 5/32" round rod?
                    #101496
                      fizzy,
                      You could comfortably mill, or file, 5/32" square; from a short length of 6mm diameter Stainless.
                      … That shouldn't be difficult to find.
                      nigel jones 5
                        @nigeljones5
                        I went down the route of milling a square end on the 1/4 shaft – got a bit of help as my mill is rubbish!
                        #101560
                        KWIL
                          @kwil
                          Yes it was 5mm square stainless. Not really a problem, just mill it down. Had to make some 4mm square brass the other day for a small job, no point in buying it.
