From my own experience – I'd go for a few cheapish10mm diameter end mills to start with. [I assume as you specify a metric ER32 chuck, you'll be working in that system.] I have a small drawer full of 10mm cutters, in varying states of bluntness, awaiting a session on the grinder. Once you get used to the new mill and what sort of feeds and speeds it will cope with, then I'd go for something of superior quality. They'll last longer and cut better, too. Later, when you've gained enough experience to actually build something, you'll doubtless find you need cutters of different dimensions, even ball-ended, dovetail or tee-slot ones perhaps.
Enjoy your Christmas presents,
