Which collet set to purchase
Home › Forums › Beginners questions › Which collet set to purchase
  • #100925
    michael chalmers
      @michaelchalmers19148
      Will be going to the show this w/e, and nedd advise on which collet set to buy.Have a myford ML7 and will possibly order a waco mill.
      Thanks
      #6386
      michael chalmers
        #100941
        Bazyle
          @bazyle
          There was a similar thread recently that advised not getting a set as most of them don't get used. Just get the one you need for the particular job.
          #100944
          chris stephens
            @chrisstephens63393
            I suspect that Michael is asking which style of collet to get, not whether a full set is required.
            Personally I would say to get an ER32 set of collets with the holder to fit your, about to be purchased, mill. In addition I would suggest getting a myford screw on collet holder, be it direct fit or flange and back plate , do not bother with a Morse one for the lathe as this prevents using long lengths to fit through the head stock.
            Again, given the choice, I would pick a collet holder with a separate back plate for the lathe because a. it allows you to, at some time in the future, fit it to another back plate for a larger machine and b, it allows you more scope to get the thing running truly by means of "bump true" and judicious use of tin foil packing. If you were to buy a direct mount holder and it were to be a off, the only way to correct it would be to re-cut the taper, which would then not align to the thread which in turn holds the closing taper. Re-cutting the taper accurately is perfectly possible but it might be outside the scope of some of the less well equipped machinists.
            It would be worth reading Harold Hall's words of wisdom, posted a few weeks ago, about collets not closing, but don't let that put you off.
            chriStephens
            PS if DC1 is reading this, why does the spell checker not recognise "collet", seems a bit odd for an engineering site.surprise
            #100962
            Terryd
              @terryd72465
              Hi,
              May I point you to this thread
              T
              #100973
              Donhe7
                @donhe7
                Posted by chris stephens on 15/10/2012 19:27:31:
                chriStephens
                Not having looked myself, but do remember seeing a "dictionary" section (or function) in some "Spell Checkers", does this version have one?? —— this function allows the user to add a new word if it is not in the basic "'checker", when it is present
                donhe7
                #100990
                michael chalmers
                  Chris
                  Thanks for the advise, will be most likely purchasing the myford screw on collet holder,
                  Thanks again
                  #100998
                  NJH
                    @njh
                    Hi Michael
                    Yes I can recommend that one but, in case you have problems fitting it, see this thread.
                    I admit I was stumped for a while!
                    Norman
                    #101001
                    JohnF
                      @johnf59703
                      Michael, possibly to late but have a look at this thread
                      Regards John
                      #101030
                      Sub Mandrel
                        @submandrel
                        Not so sure here! I have four ER25 collets plus another four home-made ones and continually regret not having a full set. The home made ones are OK for the size they are made but don't seem to collapse as well or as far as bought ones. They are made of medium carbon steel.
                        I think if you have all the sizes you are much more likely to use them instead of a chuck.
