Posted by Nick_G on 30/05/2016 11:27:14:
Posted by SillyOldDuffer on 29/05/2016 20:04:35:
What's the secret?
Cheers,
A common mistake is people charging around with their credit cards after reading the latest review or listening to others at their camera club or an internet forum. They then go and buy the latest (usually very expensive) camera body. Then having blown most of their budget end up sticking a cheaper lens onto it.! ……….. While all along there was nothing wrong with the very capable kit they already possessed. – If someone has money burning a whole in their pocket very often they would be far better off spending it on quality but simple lighting kit. They will usually get far more bang for their buck.
Personally I much prefer using a natural light source. But one has to remain practical. ………… I live in the UK
Nick
Too true but I sometimes wonder if especially when starting out and often some time later people look at other people's shots and think that just the kit they use produced the results. In some cases it will have some effect but it may be in a none obvious way. As an example I have toyed with the idea of buying a full frame camera. At the time a camera that isn't made any more. My reason would be to get better noise performance in low light. If I tried to use it for sports photography I might well find it doesn't focus fast enough. I might say low light so buy an expensive fast lens but would then wonder if it would have sufficient depth of field for when I needed to use it in low light, especially so on a full frame camera not so on one with a very small sensor such as compacts. Instead I look at what I want to shoot and set an ISO rating that I know will produce usable results with the camera I am using. If the shutter speed turns out to be too slow for hand held work I can't take the shot but may just on the off chance I can do something with it. I'm an amateur. A professional will be being paid for the work and can't really go back and say sorry need to take it again.
I don't hear Nick complaining. He's a photographer so I doubted if he would. The reason I did it was 2 fold. Dave's question just to show how much something can be changed once some one has learned how and the other goes back to the original question – want's to get into photography. People generally have expectations based on shots they see. A lot of them will have had various amounts of post processing done on them even if conditions where ideal. It can take a while to pick that up. It can also take a while to be able to tell what will come out of the camera when a shot is taken and also just how to go about taking it. Framing, lighting, camera settings and some subjects just wont produce good shots. It's also easy to over process shots. Once some one starts showing shots to other photographers other complications crop up. This is a link to one of mine.
I should replace it with one that I have done properly. It's way way over sharpened but looked fine on the monitor that I was using at the time. The contrast levels are pushed too much as well for the same reason. Due to lighting and location a lot of areas were pitch black in the jpg and even so I have lost some cloud detail.
As it is I put any old thing on there and when I work with care it's usually for a competition or to post in a photographic forum. It was taken with an Olympus EP-3, there are also others taken with the cheaper version of the same camera about on there. Mostly to try M 4/3 before buying an EM5 and later an EM 1. A lot of these were also attempts at getting to grips with pp and getting used to the camera.
