Wheel Crossing article
Home Forums Clocks and Scientific Instruments Wheel Crossing article
  • #3572
    Peter Bell
      @peterbell11509
      #44379
      Peter Bell
        @peterbell11509
        Hello,
        What is the best way to get hold of an article from ME 15th July and 19th August 1983 about wheel crossing by J Malcolm Wild?
        Also an article about a  One year Clock by W Botton to a Claude Reeve design put out as a Model Engineer series started 3rd Aug 1984?
        Peter
        #44382
        David Clark 13
          @davidclark13
          Hi There
          Try The Toolbox.
          They stock a wide range of back numbers of Model Engineer at very reasonable cost.
          regards David
          #44387
          Niloch
            @niloch
            With regard to wheel crossing, you might want to stretch the budget a good deal by purchasing the very comprehensive hard-back book authored by J. Malcolm Wild himself entitled Wheel and Pinion Cutting in Horology (ISBN 1-86126-245-0)
            Yes of course, it is a lot more expensive than a couple of back issues but then it contains far more information.
            #44393
            Niloch
              @niloch
              See also the article An Introduction to Crossing Out by Bill Morris in  issue 130 of MEW commencing page 29 (October 2007).  If you are a subscriber you will have access to this issue in the digital archive.
              Edited By Niloch on 21/10/2009 17:42:59
              #44419
              Peter Bell
                @peterbell11509
                I have got the book by J Malcolm Wild, just looked it up and sure enough the info is just what I was looking for—thanks for prompting me!  Ordered the ME back issues to look at the year clock so that is another one under way.
                Many thanks to the forum!
                Peter
                #44420
                Peter Bell
                  @peterbell11509
                  Peter
                  #52364
                  Richard Parsons
                    @richardparsons61721
                    I have written up a technique for crossing out gear wheels using a vertical milling machine and a rotary table.  If you want a copy I will E-mail you one.  Follow the instructions and you get a coconut every time.
                    Dick
