Whats this tool used for ?
Home Forums General Questions Whats this tool used for ?
  • #335044
    BW
      @bw
      #25734
      BW
        @bw
        #335049
        JohnF
          @johnf59703
          Best guess it will grip a damaged taper shank where it would slip in a standard reducer ??? but ??? lets see!
          #335061
          Phil P
            @philp
            I reckon its so you can use a drill where the tang has broken off. It will tend to grip in one direction and release in the other direction, thus allowing the drill to be removed easily, if you use a standard reducer the broken tang drill would be difficult to remove.
            I have never seen one of these before, but they look as though they might do the job.
            Phil
            #335065
            not done it yet
              @notdoneityet
              I reckon it would work and then likely jam!
              I’m thinking of the pipe bending springs where you can remove them by twisting anticlockwise to contract the diameter a bit for easier removal.
              Unfortunately, in this case there will be a morse arbor jammed inside making it very difficult to loosen if there is any free spring close to the tang.
              Might work but i would not risk it. Anyway, cheaper to have a spare reducer!
              #335067
              Phil P
                @philp
                In theory you should be able to drive it out of the spindle using a standard removal wedge, then as you say, twist the spring to release it from the broken tang drill.
                I do agree with you that it is not something I would want in my own spindles.
                Phil
                #335069
                jimmy b
                  @jimmyb
                  That's a new one for me. Been doing this job for 34 years and not seen anything like that!
                  Can't wait to find out what its for.
                  Jim
                  #335071
                  robjon44
                    @robjon44
                    Hi guys, such devices are generically called use-em-up sockets, the commonest of which is a forged morse taper with a flat on 1 side of the bore ie it is D shaped, take damaged drill, tidy up broken tang, grind dirty great flat on taper till it will fit in the new socket along its full length, knock it in up to your usual standard of agricultural violence, this is NOT precision engineering, regrind drill point, carry on, quick, cost effective, blah blah.
                    Bob H.
                    #335093
                    David Standing 1
                      @davidstanding1
                      It looks like they only really get used on the other side of the pond, which is why they are unfamiliar to us in the UK.
                      #335097
                      Hopper
                        @hopper
                        Looks like it would be cheaper than buying a whole new say 2" diameter drill bit after the tang has been sheared off. They might not bother with getting it off again, just leave it in place?
                        #335112
                        mark costello 1
                          @markcostello1
                          Never seen over here also.
                          #335123
                          norman royds 2
                            @normanroyds2
                            was it made china
