What’s the strangest project you’ve ever seen in an old ME or MEW?
Home › Forums › Model Engineer & Workshop › What’s the strangest project you’ve ever seen in an old ME or MEW?
Viewing 25 posts - 1 through 25 (of 38 total)
  • #38457
        In MEW we occasionally cover 'domestic' repairs as these can involve interesting machining tasks.
        Perhaps we should take a leaf out of ME's book and have a series on making a microwave or a nutri-ninja?
        #332548
        John Haine
          @johnhaine32865
          Many years ago on Tomorrow's World they had a hot dog maker that applied mains voltage across a frankfurter to heat it up. Definitely a candidate for a project I think.
          #332549
          John Haine
            @johnhaine32865
            Oh, and in that issue I see that they also have an article on a "small capacity milling machine" – presumably to make flour for small cakes in the electric mixer?
            Edited By John Haine on 18/12/2017 14:40:23
            #332550
              Answering to the thread title:
              An Edision cylinder phonograph … cleverly converted into a sander !!
              crying 2 MichaelG.
              Edited By Michael Gilligan on 18/12/2017 14:41:36
              #332554
              Ady1
                @ady1
                I think there was a build your own fridge article at one point
                As various home technology came on stream over the decades there were a few Heath Robinson attempts to get ahead of the neighbours
                I seem to also recall a motorised lawn mower which could have been used in a Mad Max movie
                Edited By Ady1 on 18/12/2017 14:57:17
                #332560
                  From 'Model Engineer and Electrician' No 949:
                  Recommended for unsticking rusty pistons…
                  Edited By SillyOldDuffer on 18/12/2017 15:45:54
                  #332572
                    laugh
                    #332602
                    David George 1
                      @davidgeorge1
                      How to start a tractor with a shotgun cartridge ?
                      David
                      #332610
                      not done it yet
                        @notdoneityet
                        Not particularly a project for a Field Marshall. It was an factory alternative to cranking when on your own (if very lightly – or weakly – built) or in the depths of winter when manual cranking was much more difficult. Making you own reloads might have been a project!
                        #332616
                        Simon Collier
                          @simoncollier74340
                          I seriously considered making a dough hook for my mill. Even expensive kitchen mixers aren't really man enough for the job.
                          #332618
                          duncan webster 1
                            @duncanwebster1
                            Posted by David George 1 on 18/12/2017 18:42:38:
                            David
                            When I worked in gas turbines we put in a proposal for a man portable generator for the army which we proposed to start with cartridges. I left before I found out whether they got the job, but I kept on asking what do you do when you run out of cartridges? A pull cord isn't a lot of use on even a small turbine.
                            #332619
                              Posted by duncan webster on 18/12/2017 20:05:04:
                              David
                              Choose a NATO standard cartridge so that in an emergency you just hoik the bullet out of one?
                              #332624
                              not done it yet
                                @notdoneityet
                                They would need wads and a crimper – modern propellants only burn fast and clean under pressure. Not a real problem, I suppose – just use a far bigger case than required?
                                One problem with starting those Field Marshall engines was if that smouldering insert (of the size he was using) got trapped under the decompression valve. Didn't happen often, but was a bit of a b****r when it did, apparently. The starting handle supplied was long enough for two people to swing it. It is hard work on your own!
                                #332639
                                Clive Hartland
                                  @clivehartland94829
                                  I had a 27.5 Kva generator on my sig. Starting was HP air at 600 psi which gave 3 attempts to start and there was a Balastite cartridge start device fitted also. If someone forgot to fill the air bottle again I used to kick them in the rump. Only thing was they would not issue cartridges unless it was a continuous minus 18 C. It also had a starting handle which was big enough for 2 men to use. On a cold morning I could hardly turn the engine over alone.Many a time in the cold on exercise i would leave it ticking over at night, it used to keep the sentries warm.
                                  #332660
                                  Ady1
                                    @ady1
                                    Ships engines always use air
                                    If the old man was stopping/starting too much in port the engine room would let him know
                                    "You've only got three starts left captain!"
                                    #332662
                                    duncan webster 1
                                      @duncanwebster1
                                      Posted by Neil Wyatt on 18/12/2017 20:07:50:
                                      David
                                      From memory they were a lot bigger than a bullet, more like an overgrown shotgun cartridge.
                                      #332665
                                      Jens Eirik Skogstad 1
                                        @jenseirikskogstad1
                                        Converted from milling machine to mixing machine laugh
                                        See this movie the plane is started up with Coffman combustion starter (cartridge starter with other word). smiley
                                        s
                                        Edited By Jens Eirik Skogstad on 19/12/2017 02:15:14
                                        #332666
                                        Geoff Theasby
                                          @geofftheasby
                                          An x-ray machine, about 1914 in M.E. X-ray your pets!
                                          Geoff
                                          #332669
                                            @jenseirikskogstad1
                                            Atomic energy lab for childrens laugh
                                            not done it yet
                                              @notdoneityet
                                              Not 'overgrown' at all. A normal gauge cartridge. Admittedly rather bigger than a .410, but they just used the size for the job. It was an 8 gauge. Some wildfowling shotguns used a 4 gauge cartridge. I suppose most out there only think of the most common shotgun size – the 12 bore.
                                              You can work out the diameter using the standard density for lead and 4/3 Pi r^3. Without checking, a 12 gauge is about 0.718".  More like a cannon shell case than a bullet, I suppose.
                                              Edited By not done it yet on 19/12/2017 07:33:51
                                              #332680
                                              Martin Kyte
                                                @martinkyte99762
                                                . . . . . and not one mention of an Adept lathe rebuild ?
                                                ;0)
                                                Happy Christmas Neil
                                                Edited By Martin Kyte on 19/12/2017 08:43:54
                                                Edited By Martin Kyte on 19/12/2017 08:44:20
                                                #332682
                                                  Posted by Jens Eirik Skogstad on 19/12/2017 05:48:28:
                                                  K3WL!
                                                  It has its own Wikipedia page.
                                                  "Among other activities, the kit suggested "playing hide and seek with the gamma ray source", challenging players to use the Geiger counter to locate a radioactive sample hidden in a room."
                                                  I have found someone's blog of making a small fusion reactor… it did generate a tiny amount of energy, much less than what was put in (not cold fusion).
                                                  Edited By Neil Wyatt on 19/12/2017 08:51:57
                                                  #332698
                                                  John Field
                                                    @johnfield81618
                                                    ME for Jan 14th 1943 had a handy article on "Improving the Mark 2 Sten Gun"
                                                    #332720
                                                    simondavies3
                                                      @simondavies3
                                                      Admittedly it was April 1899 and an article within refers to Signor Marconi's successful experiments and his claim that he should be able to transmit across the Channel to France!
                                                      I passed on the majority of my old MEs a few months back but wanted to retrain the two I had from 1899 – just for this sort of topic!
