What to use for New Worktop?
Home Forums General Questions What to use for New Worktop?
Viewing 7 posts - 26 through 32 (of 32 total)
  • #458620
    ega
      @ega
      old mart:
      Good idea about the metal working vice; woodworkers often temporarily grip a batten mounted vice in the wood vice which is, of course, normally flush to the surface of the bench.
      That marine ply must have cost a bob or two!
        MIne are mill bench – kitchen worktop. Home made bench – 3/4" WBP ply. 'Electronics bench' just plastic surfaced chipboard. One for my mini lathe and bench drill that is topped with a mahogany veneered chipboard door. 3D printer stand all made of 1/2" wpb ply and the SC4 is on the steel stand.
        pgk pgk
          @pgkpgk17461
          Options abound. My side 'bench' bit like kitchen style is MDF with gloss paint but is really only where I put stuff down and have a grinder and sander and bench dril on their own extra mdf plinths.
          I have an 'assembly table' where i keep PC and a chair and pretend I'm thinking . For some projects I clear it off and screw templates down. Itls an old dining room table with a sheet of MDF. Once a project is done I fill the holes with (suprise) filler and scrape it level with one of those wall scrapers.
          Finally I have a small free-standing bench i made storing metal on the cross members underneath and with some 2×4's as the top. that gets anything dirty (or handy) put on it. Blobs get scraped off, the top gets wiped down with an old Tshirt as a defining grubby old oily rag.
          One option no-one mentions is that you can easily paint almost any surface with slow setting epoxy which will settle level and is very resiliant..can always be sanded and recoated if you're really fussy.
          #458698
          Alistair Robertson 1
            @alistairrobertson1
            A few years ago I got cut-offs of Corian which were perfect for the tops of my benches made from 30mm thick beech boards about 125mm wide. I got them from a local supplier who cut them out of bigger sheets as part of some contract they had which left about 250mm all around with the 1.5 meter x 2 meter dimensions.
            I got the off-cuts for about 10% of the price of a virgin bit of material but I was probably in the right place at the right time and the Corian has been my bench surface for about 15 years and is still in very good condition.
            #459211
            The Novice Engineer
              @thenoviceengineer
              Mine are 20 mm Block Board with 14g Aluminium sheet covering, folded over 1" down at the front and a 2" Upstand at the back. Been good for last 30 years and should be OK for the next 20 !
              #459212
              Mike Poole
                @mikepoole82104
                Phenolic faced plywood was used in our factory as flooring on a production line, it had a patterned finish to enhance grip but it is also available with a smooth finish, it seemed to be very hard wearing and was impervious to liquids. I believe it is also used for more durable shuttering applications.
                #459249
                James A
                  @jamesalford67616
                  Thank you for the suggestions. In the end, I have used kitchen worktop again. I did consider timber or heavy boards with a replaceable top of lino or the like, but wanted to avoid any raised edges on the worktop. I had that last time and detritus kept getting caught in it. The alternative would have been to lay it under the vice et al, needing them to be removed to replace the top.
                  Cost and the ease of getting material in the current circumstances was another consideratio. I really want to get the job finished sooner, rather than later. The nearest place where I can get reclaimed boards and the like is a fair way of and I would need to arrange transport.
                  James.
                  Edited By James Alford on 24/03/2020 07:16:13
