I suggest that it is very likely to be the 9 x 1.5 Trapezoidal thread identified in the link from pgk pgk. Motor cars are mass produced, with components from all over the world, so if possible everything is built to a standard of some sort. This means that cutting tools, gauges, and other checking kit is readily available, rather than 'special', and so one-off, expensive, and hard to replicate if damaged or an alternative supplier is sought.
It is also the case that coarse, and squarish threads like this are preferred for plastics as the properties are quite a lot different from the metals with which we are more familiar. So, a metal replacement for a plastic part has a plastic-style thread.
Cheers, Tim
