Posted by SillyOldDuffer on 09/07/2017 16:28:50:
Posted by Nige on 09/07/2017 12:57:03:
… I think the cross slide on the ML4 is rigid enough and also doesn't appear to have much 'play' in it.
Nige
Yes indeed but the booby trap is that a lathe cross-slide isn't designed to deal with milling forces. Normally the cross-side pushes a single-point tool against the work. The force on the tool is pretty much in one direction and the cross-slide is engineered to deal with it. Also, because the force is unidirectional, any slack and backlash in the system are taken up and held as the cut is applied. It's a stable arrangement that works well.
Milling applies dramatically different forces and it doesn't help that a milling cutter has much bigger cutting edges than a lathe tool. Because the tool is spinning, so is the direction of the cut. The cross-slide is forced down, right, up and left repeatedly. It is pushed hard in directions the lathe designer never took seriously. And any slack in the screws and gibs will allow enough movement to cause trouble.
The best way to get a feel for what works and what doesn't on your lathe is to try it. It's very educational!
There is really no fundamental difference in the construction of the slides between a lathe and a mill in my experience. The biggest differences appear when you get to the headstock in terms of collets and drawbars rather than a chuck, and the arrangement and movement of the slides is obviously different.
If anything, a modern lathe relying on a polyform bedway slide is more rigidly constructed than a simple vee groove simply to counteract the twisting motion Imposed on the saddle during rack feed. Probably one of the main reasons why my Clarke never had a rack and pinion feed (simply directly bolted to the feednut and handle.
(You may have seen the post on my failed experiment with a rack/pinion feed, due to the reason outlined above, though I think I may have found a clever workaround, it'll work this time I think!)
As far as I know my mill uses vee groove slides, one thing I would agree is that with a mill it's a lot heftier than the cross slide though, as the travel tends to be far shorter on a lathe. In theory with a sensible set up there is no reason why he couldn't do milling on a lathe, I have milled a cast iron piece on the lathe before and found I could take quite a cut with it. Just make sure those bolts are done up tight on the vise, Nigel!
Michael W
Edited By Michael-w on 09/07/2017 21:04:15
