What size Lathe to use to make a 1,2 traction engine
Home › Forums › Beginners questions › What size Lathe to use to make a 1,2 traction engine
Viewing 13 posts - 26 through 38 (of 38 total)
  • #351515
    Bruce Edney
      @bruceedney59949
      Hi Henry
      I would suggest heading along to the Canterbury Society of Model Engineers if you haven't already. I am sure you will find them to be very helpful.
      Cheers
      Bruce
      #351516
      Henry Ruiter
        @henryruiter35703
        Halfway through last year I start steam plant I brought the engine from OZ( similar to a Stuart 10H)and my dad made the boiler for me it’s 100mm x 240mm I got all the fittings and It was finnished it January this year.
        Thanks Henry
        #351517
          Please DON'T suggest that metric Minnie to anyone let alone a beginner as there are major problems with the boiler drawing unless anyone can work out how you fit the cylinder retaining bolts from inside the boiler crook
          Henry, in your other post you wanted an engine to pull a couple of people about, you will struggle to do that with a 1" Minnie, Allchin and the smaller Burrell GMT
          #351520
          Henry Ruiter
            @henryruiter35703
            What model would you suggest then. This why I’m here to learn from you guys you would have more information than I could find by myself.
            Thanks Henry
            #351521
            Henry Ruiter
              @henryruiter35703
              Are the Sieg lathe/Mills any good.
              Thanks Henry
              #351522
                With the budget you have (£3500 or 7000nzd) by the time you have bought a lathe and tooling for it and possibly a mill you won't have a lot left for a large 2" engine which would be the minimum for pulling people about on a good surface. Infact you will struggle to buy the castings and all the other materials for that let alone anything else. Think again about what you can afford and what you want to do with the engine and also do you have 2-4 years of spare time to make it as you will need to spend 1000-1500hours on it if making from castings.
                I built my 2" Fowler on a Sieg mill and far eastern lathe
                Edited By JasonB on 25/04/2018 07:36:28
                #351525
                Henry Ruiter
                  @henryruiter35703
                  Whats a relistic budget then and what would be included in a casting set for a 2″- 3″ traction engine.
                  Thanks Henry
                  #351527
                    Off to work now so a quick answer
                    Have a look at this pricelist for a 2" Fowler as it shows most of the parts you get and add up the costs. Then allow £1000 plus for general materials, copper for boiler etc. Don't forget it may well cost several hundred to get the parts to the other side of the world.
                    You will need the SC8 Sieg machine to make that @ £2500 plus tooling at least another £500-1000. then there is the question of a mill and then all the other small tools etc you will need along the way so easily another £1000
                    Edited By JasonB on 25/04/2018 08:22:30
                    #351646
                    Henry Ruiter
                      @henryruiter35703
                      So I would need a budget more of $8,000-$15,000 or so.
                      Thanks Henry
                      #351663
                        Realistically yes.
                        #351666
                        Henry Ruiter
                          @henryruiter35703
                          Ok thank you.
                          Thanks Henry
                          #351956
                          Howard Lewis
                            @howardlewis46836
                            My 4 cents.
                            In the future, you are pretty sure to want to expand your horizons, so think about whether you might want a larger machine . You can do small work on a big lathe, but the other way round is a LOT more difficult, if not impossible.
                            Marvellous work has been done on ML7s, but if you eventually yearn for a 4" engine, you might struggle.
                            #352019
                            Henry Ruiter
                              @henryruiter35703
                              There must a some point that you might as well go buy a real traction engine I treams of scale.
                              Thanks Henry
