What is the strongest way to bond styrene onto ABS?
Home Forums Beginners questions What is the strongest way to bond styrene onto ABS?
Viewing 11 posts - 26 through 36 (of 36 total)
  • #211447
    Russ B
      @russb
      3D printing machines are not uncommon these days, and are probably what a lathe and mill was to many 50 years ago.
      So you (or someone else) could print a labyrinth of HIPS and HDPE layer by layer (both of which are available in 1.75mm or 3.0mm spooled filament – although not that common, especially not HDPE, partly as its nearly impossible to get it to bond to anything, and it degrades slightly when extruded – I think)
      This would be completely impossible using conventional methods and on a dual extruder machine the HDPE and HIPS could be interwoven without needing to stop and change the filament! I would say probably start with HIPS as it will more easily bond to the build plate and then capture pockets of HDPE in the HIPS and build up layer by layer from there – its as simple as designing the part in 3D and using a software like MatterControl with MatterSlice or Slic3r it will automatically "slice" the 3D part into layers of your chosen thickness and print away automatically.
      I wonder if a thin piece could be 3D printed made up of dotted HIPS and HDPE as a sort of bonding medium via suitable chemicals between pieces of pure HDPE and HIPS
      I have a large 3D printer but it's a single filament machine and I'm not planning on converting it to a dual material/color any time soon (walking before I can run!)
      Here's the sort of quality a novice (that's me!) can achieve. This was Verbatim ABS printed in 0.1mm layers through a "medium" 0.5mm nozzle @230°C on a 80°C borosilicate (Pyrex?) build plate with Elmers Disappearing Purple glue (as ABS doesn't stick to glass!) – All good (clean!) fun and easy to keep SWMBO happy with pretty pussy cats for calibration pieces
      laugh
      And for my next trick: http://www.thingiverse.com/thing:536050
      Edited By Russ B on 10/11/2015 14:38:16
      Edited By Russ B on 10/11/2015 14:39:31
      Edited By Russ B on 10/11/2015 14:41:03
        John,
        Look up "Threaded Inserts and Other Hot Topics" by Mark Noel in MEW 225. All about how to perform the operation in the home workshop.
        John Smith 47
          @johnsmith47
          Posted by Neil Wyatt on 10/11/2015 20:16:54:
          John,
          Do I have to be a subscriber to see this?
          I searched online briefly but without success …
          Thanks
          #211675
          Martin Kyte
            @martinkyte99762
            What about
            Your heading says styrene to ABS but then you talk about Polyethelene so it's a little confusing?
            regards Martin
            #211707
            John Smith 47
              @johnsmith47
              Posted by Martin Kyte on 12/11/2015 08:30:36:
              What about
              regards Martin
              I have two different requirements running in parallel and I may have got my threads confused. Humble apologies.
              Fwiw, on your link it says:
              WELD-ON 2354 is formulated for bonding ABS, styrene (general purpose high impact), acrylics and poly-carbonates to themselves. It should not be used for joining dissimilar materials such as: ABS to styrene, ABS to acrylics, ABS to PVC or PVC to styrene.
              #211711
              Martin Kyte
                @martinkyte99762
                But it does say
                WELD-ON® 1802 is formulated to bond acrylic (poly-methyl methacrylate), ABS, cellulose, acetate butyrate, rigid PVC, and polystyrene to themselves and to each other.
                #211716
                  Posted by John Smith 47 on 11/11/2015 19:12:04:
                  John,
                  Thanks
                  Hello John,
                  I'm afraid yes, you need the back issue (225 & 226) or a digital sub to allow you to access the archive.
                  I'm looking at whether the article could be put on line, but it's rather long and complex, so it will need to be edited down, so this might not happen.
                  John Smith 47
                    @johnsmith47
                    Posted by Martin Kyte on 12/11/2015 12:03:29:
                    But it does say
                    Good point – i.e. it flatly contradicts itself!
                    So far I have been using ABS and styrene in the same model as if there were both styrene, bonding with Tamiya Extra Thin or EMA Plastic Weld. Both seem to bond pretty well even though I have not formally tested the strength of the bonds. Fwiw, on balance I slightly prefer the Tamiya as it seems be slighly less "hot" as they say and seems to give slightly longer working times being as it evaporates a bit slower.
                    #211727
                    Martin Kyte
                      @martinkyte99762
                      Are there not two products 1820 and 2354 ?
                      Martin
                      #211735
                      John Smith 47
                        @johnsmith47
                        Posted by Martin Kyte on 12/11/2015 13:33:23:
                        Martin
                        At a quick skim the way the page is structured, that wasn't completely obvious but yes, you are correct. Apologies – I was skim reading too fast.
                        #211753
                        John Smith 47
                          @johnsmith47
                          Posted by Neil Wyatt on 12/11/2015 12:21:23:
                          John,
                          Thanks
                          Hello John,
                          OK I'm tempted to go for a 3 month trial subscription – possibly of print and digital. Any idea where I can get a promo code from?
