What are you doing
What are you doing
Home Forums The Tea Room What are you doing
Viewing 25 posts - 1 through 25 (of 25 total)
  • #35889
    Stephen Follows
      @stephenfollows82099
      Stephen Follows
        What's everyone doing in the lockdown? I'm assuming there are other pastimes as well as model engineering that you are not doing. Mine's playing in a brass band (or not). No rehearsals, no concerts. Gave my workshop a good clean. Thinking about changing the layout and building in a bit more bench space.
        One thing I do have a problem with is damp in the winter months.Think I may have to put in some sort of permanent heater on a thermostat. Probably cost a fortune to run.
        That should occupy for a couple of weeks at least!
        #468476
        Steviegtr
          @steviegtr
          Posted by Stephen Follows on 01/05/2020 22:10:07:
          I have a dehumidifier that is always on. My garage is pretty water tight but in winter there is always the condensation issue.
          #468477
          Steviegtr
            @steviegtr
            Been tidying up my workshop & looking at more tool cabinets to hold cutters etc. Drawing up a pergola for the rear garden, with hope of growing grape vines up it .Steve.
            #468490
            Stephen Follows
              Does the dehumidifier cost much to run? I was considering an electric radiator but could end up costing £10 to £15 a week to run. Too much!
              #468491
              Steviegtr
                @steviegtr
                Posted by Stephen Follows on 02/05/2020 00:06:32:
                No not at all. I have pic somewhere of it. I bought it years ago for a boat we had, for the winter. It is the compressor type with a 1 litre catch tank . Or it can be piped outside. I never turn it off. The settings are for the humidity. I think mine is set for 65% so it only runs when needed. Some pics. This is in the main garage where my car & bikes are. So a big area & not really noticed any difference in leky bill.
                Steve.
                Edited By Steviegtr on 02/05/2020 00:33:30
                #468494
                Bazyle
                  @bazyle
                  I run several small dehumidifiers mostly overnight on the cheap rate but the workshop one is full time. They use about 180W when the compressor is running then drop to about half that on a roughly 50% duty cycle modified by the humidity setting. Once the temperature is up around 16c and they've got the humidity down they spend a lot of time off and test the air for a minute a few times an hour. I recon they collect about a litre a day when its damp and that is recovering the energy of vaporisation so I'm getting more heat than I pay for. Sometimes I will notice the workshop one come on a few minutes after I go in there as it senses me breathing out moisture.
                  I have been spending a lot of time moving wood around. In the fine weather I would have liked to do a lot of chainsawing and painting up a ladder but didn't like to do anything risky. Shifting a few 4ft logs 200 yds uphill over rough ground constitutes my daily exercise quota. I hardly seem to have achieved anything relative to the time I've had at home though.
                  #468519
                  David George 1
                    @davidgeorge1
                    I am making a wire drawing jig for a local jewelry maker and teacher.
                    David
                    #468528
                    Speedy Builder5
                      @speedybuilder5
                      That's an interesting set of "pliers" there David. Are they special wire drawing grippers ?
                      For me, I tidied the workshop and then trashed the whole place by planing down lots of walnut to make a cabinet for my grandaughter.
                      #468540
                      David George 1
                        @davidgeorge1
                        Hi Speedy Yes they are wire pulling pliers. The ring pulls the handles together the harder you pull the harder they grip.
                        David
                        #468546
                        Bob Stevenson
                          @bobstevenson13909
                          Actually, despite the 'visitation of the Pestilence' I'm busier than ever…….loads of jobs in the house that I should have done before (according to herself!)….helping to set up zoom sessions for members of Epping Forest Horology Club…..then theres my ongoing current clock build in which I'm reworking a Wilding design for skeleton clock……also, nearly done on a couple of pneumatic engraving tools I have made from 16mm stainless bolts/nuts…….and finally, seriously near to changing the tool post set up on my WM 180…
                          Like OP Stephen I too used to be a 'bandie' playing in brass bands for over 50 years….I'm still on the edge of the movement and have a couple of close friends still 'serving' who have effectively lost their bands due to the emergency as bfrass bands don't really transcrive to 'zoom' very well, unfortunately.
                          #468554
                          Samsaranda
                            @samsaranda
                            Stephen, I run a dehumidifier in my workshop, it is a small unit mounted on the wall with a drain to outside, I have it on a time switch to coincide with the economy 7 off peak rate. I also run a small oil filled radiator, 750 watts, which is set to keep the temperature about 10 degrees C, the radiator is able to run 24 hours a day but the thermostat keeps the running costs down. I have found that this setup keeps humidity at bay and when you need to use the workshop it doesn’t take long to reach a reasonable working temp by switching up the radiator output. Running costs are quite reasonable, however we are large users of other power in our household as I run two large ponds with pumps and air pumps etc, 360 days a year, costs are a lot lower since I installed solar panels 18 months ago.
                            Dave W
                            #468564
                            Mick Henshall
                              @mickhenshall99321
                              20200501_113425.jpgfinishing off Suffolk Punch overhaul its a 1987 98cc mower. Have a number of suffolk engines, to old to work on cars so these are a good substitute
                              Mick 🇫🇴
                              #468565
                              Mick Henshall
                                @mickhenshall99321
                                Here is another pic
                                #468575
                                Bazyle
                                  @bazyle
                                  That's one clean mower. Reminds me I must tackle the cricket club Balmoral. It cuts well but the carb is a pain and keeps dribbling or cutting out despite fitting a filter. We have been told groundsmen can work as one person on a whole cricket pitch achieves adequate distancing. Trouble is we have already missed several fundraising events and will be lucky to get a match in before September when it starts raining (even harder).
                                  #468949
                                  David George 1
                                    @davidgeorge1
                                    Just about finnished the wire drawing jig. I had to bore some holes for the plate holding blocks.
                                    A bit long but only Ally so no problem.
                                    Tapped to mach blocks and first test.
                                    Just clean up and Finnish debur channel.
                                    David
                                    #468955
                                    Steviegtr
                                      @steviegtr
                                      Almost finished a Parting off tool for the Quick change toolpost. Just a height bolt to fit & a good clean up. Pictures shown. Managed to break 2 small 2.5mm milling cutters. 1 on the go the 2nd , setting up the job & snagged it. At that point I told myself off & said time to lock up for the night. When you start messing up it's time. Was 11:45p.m though. I realise the positive rake will need grinding back to a negative rake. I assume the cutter was not meant for a little Myford.
                                      Steve.
                                      Edited By Steviegtr on 04/05/2020 00:25:47
                                      Edited By Steviegtr on 04/05/2020 00:26:35
                                      Edited By Steviegtr on 04/05/2020 00:28:11
                                      #468956
                                      Steviegtr
                                        @steviegtr
                                        Forgot to say all made from mild steel EN1A. Would like to harden , but not got the facility to do.
                                        steve.
                                        #468965
                                        Daniel
                                          @daniel
                                          Posted by Mick Henshall on 02/05/2020 10:14:43:
                                          …finishing off Suffolk Punch overhaul its a 1987 98cc mower. Have a number of suffolk engines, to old to work on cars so these are a good substitute
                                          Mick 🇫🇴
                                          smile That brings back some memories, Mick.
                                          My Grandfather had one. It would have been around 1974/5, and I would have been seven or eight at the time.
                                          Was the first powered vehicle I was allowed to 'drive'. Hours of fun being more or less dragged along behind it.
                                          One thing I wasn't that keen on was, in order to stop it, one had to press a flap of steel onto the top of the spark plug. Gave me a healthy belt every time. From memory, it took me a worringly long time to discover that the employment of a piece of timber (dry), worked better.
                                          Happy days.
                                          ATB,
                                          Daniel
                                          #468972
                                          Old School
                                            @oldschool
                                            Over the lock down I have built a Russian tether car kit from the 70s/80s it comes with a die cast chassis and the rest of the material to build it requires a lathe at least to build. The kits must have been produced in big numbers. They are still available on eBay.
                                            The then eastern bloc had youth houses to encourage the youngsters to take up a hobby the one in Estonia still exists and has a nice workshop for the youngsters to use. They are fighting to save it at the moment they want to knock it down and build houses.
                                            #468973
                                            not done it yet
                                              @notdoneityet
                                              Excuse me for asking, but why were you using cutters that small? I see nothing that requires small, fragile cutters on that piece.
                                              Not sure about what appears to be some awkward angles. I have a parting tool holder which holds the blade at an angle – it is so much of a PITA that it never gets used. A holder where one can extend, or retract, the blade without needing to re-set the cutter height is so much more preferable, IMO.
                                              #468988
                                              martin perman 1
                                                @martinperman1
                                                I decided to upgrade my horizontal band saw, I've had it for about ten years after being given it by a neighbour, it was in a bad state as it had stood outside for several years so I stripped it and got it back to order, it didnt have a length stop or a table for vertical use.
                                                The table is just a piece of scrap 6mm plate and the length stop is made from scrap, the stop is made from a piece of bar and some Aluminium strip, I didnt have any small screws to join the two parts together so I used Gorilla glue and left them clamped together for 24hrs, yesterday I held the stop in the lathe to drill a 12mm hole through the plate, I spun the lathe up to check for vibration and to test the glue and once happy I drilled the hole, very impressed with the glue.
                                                On the long shaft that supports the stop I marked 50mm steps up to 250mm, I dropped the blade down and measured 50mm from the blade and made a shallow hacksaw mark and so on to 250mm then highlighted the marks with permanent pen, this will allow me to cut lengths without use of the tape measure.
                                                Martin P
                                                #468998
                                                Les Jones 1
                                                  @lesjones1
                                                  Have a look at this design for a saw table for these band saw that folds out of the way when using the bandsaw horizontally.
                                                  Les.
                                                  #469011
                                                  martin perman 1
                                                    @martinperman1
                                                    Posted by Les Jones 1 on 04/05/2020 09:56:29:
                                                    Les.
                                                    Thanks for that, I found some more aluminium yesterday in one of my sheds so may follow the design.
                                                    Martin P
                                                    #469041
                                                    Bazyle
                                                      @bazyle
                                                      There is a 4×6 bandsaw group on groups.io which in the last week got a request from a chap at Rung-fu for suggested improvements. Rather unusual and a lot of people chipped in.
