What are these change gears for?
Home › Forums › General Questions › What are these change gears for?
  • #26630
    AdrianR
      @adrianr18614
      #410714
      AdrianR
        @adrianr18614
        I have a 127/100 combination gear that I am trying to identify what lathe it is for.
        DP 18
        PA 14.5
        Shaft 5/8"
        127t thickness 3/8"
        100t thickness 7/16"
        Overall thickness 13/16" ie same as 3/8" gears with 1/16" clearance.
        Any one know what lathe would use this?
        #410721
        Clive Brown 1
          @clivebrown1
          Similar to my Boxford ME10.
          #410734
          AdrianR
            @adrianr18614
            While digging trough more boxes I found 49t change wheel of similar dimensions that meshes fine. In the casting it has an embossed diamond with S&B. Could that be Smart & Brown?
            #410735
            Brian Wood
              @brianwood45127
              Adrian,
              That logo was the one used by Smart and Brown. The 100/127 conversion gear would very likely have been made for the Sabel lathe, S & B's copy of the US Southbend
              #410742
              AdrianR
                @adrianr18614
                Ahha, that is exactly what I have This site has a picture
                12 years ago I helped my wife clear her step fathers workshops. Most had already been sold off, the bulk of the remainder was red rust thanks to a leaky roof and a break in. Heart breaking seeing the slip gauges over the floor in a rusty puddle. Now seeing that Sabel I realise that was the rusty mound in the corner. I did look at it and wanted it, but at the time did not have the space. Oh for a time machine.
                #410760
                Pete Rimmer
                  @peterimmer30576
                  That's quite a valuable gear being similar pitch to Boxford. If you have no use for it then put it on eBay with a low start you might be pleasantly surprised at what it fetches.
                  #411143
                  old mart
                    @oldmart
                    I have just looked up the change gear specs for the S&B Sabel, and they are slightly different from your figures.
                    18DP 20PA 3/8" wide and 9/16" bore.
                    The double gear would likely have a larger bore.
                    Edited By old mart on 27/05/2019 14:28:06
                    #411210
                    AdrianR
                      @adrianr18614
                      Hmm, maybe the compound gear is Boxford then, which is good as I am thinking of selling it.
                      #411215
                      Martin Connelly
                        @martinconnelly55370
                        It could also be used as an indexing plate for anyone who wants to cut 127 tooth gears to suit some other gear profile. Advertise it for this use as an option and you may get more interest in it.
                        Martin C
                        #411254
                        old mart
                          @oldmart
                          The lathes website sells gears for Boxford
                          https://store.lathes.co.uk/parts/boxford-and-south-bend-9-inch-changewheels-tumble-reverse-gears
                          Edited By old mart on 27/05/2019 21:37:35
                          #411269
                          Pete Rimmer
                            @peterimmer30576
                            I think it is probably Boxford too. Boxford and Denford both used 18DP change gears but the Denford ones were 20pa.
