Warco WM250VF Face Plate
Home › Forums › Help and Assistance! (Offered or Wanted) › Warco WM250VF Face Plate
  • #312369
    John Slaven
      @johnslaven66698
      Hi All,
      Need some advice here. Was going to start cleaning up a motorcycle rear disc on the face plate. When checking the alignment I found the outer face to be 0.13mm (5.1 Thou) out and the inner face to be 0.07mm (2.75 Thou) out. I have cleaned all the mating surfaces on the headstock and the face plate to rule out any dirt causing the misalignment. Should I take a small skim off the face plate to true it up? Any other advice would be welcome.
      Cheers the Noo
      John.
      #33054
      John Slaven
        @johnslaven66698
        #312370
        Rik Shaw
          @rikshaw
          Yes John – a light skim on a (new?) faceplate would be quite normal to true it up. Make sure that the gibs on the cross slide are all adjusted correctly before starting the skim.
          Rik
          #312371
            Quite usual to skim a new face plate. Mark it like the chuck so you can make sure it goes back on in the same position next time.
            #312377
            Nick_G
              @nick_g
              I bought a 3rd party D1-3 faceplate of far east origin for my Boxford. It was waaaaaay off and needed from memory about 30 thou skimming.
              Nick
              #312379
              John Slaven
                @johnslaven66698
                Hi Rik, Jason and Nick,
                Thanks for the reply. I'll get it trued up with a wee skim. I've center punched the mounting flange next to the "0" mark on the headstock so I can re-align the face plate. Many thanks for your help.
                Cheers the Noo
                John.
                #312399
                John Slaven
                  @johnslaven66698
                  Hi All,
                  Face plate true'd up and now spot on. Thanks for your help.
                  Cheers the noo
