If you want concentricity, use a 4 jaw chuck and clock the work. Collets were intended for repetition work, so a bit expensive to use for holding one off jobs. Likely to take longer to change the collets than to adjust the jaws on a 3 jaw, but possibly not quite as accurate as clocking in a 4 jaw, (although quicker changing workpieces)
Depends whether you are pursuing a hobby or are time pressured, as if on piecework.
A complete ER40 set up, will cost more than a 4 jaw chuck, and unless flange mounted, will not allow work to pass through the Mandrel.
Depends on what you intend to do, and how much you are prepared to spend.
