Warco WM18 lead screws upgrade
Home Forums General Questions Warco WM18 lead screws upgrade
Viewing 7 posts - 26 through 32 (of 32 total)
  • #446156
    Enough!
      @enough
      i have re thought thing and am still thinking about a ball lead screw for the Z axis. The would mainly to make the up/down of the head easier
      We-e-ell … see previous comments about back-driving with ballscrews.
      petro1head
        @petro1head
        Posted by Bandersnatch on 12/01/2020 16:48:05:
        Ah, had missed that
        so anthing better than the std warco setup
        #446176
        not done it yet
          @notdoneityet
          90 degrees now, so question might be how much when you got it? (and was it new?). 360 degrees will be point of failure. smiley
          #446190
          Enough!
            @enough
            Posted by petro1head on 12/01/2020 18:12:57:
            Ah, had missed that
            Previously we were discussing ballscrews in relation to the X and Y axes. Here you had moved on to the Z-axis. If the ballscrews back-drive on the Z-axis, the head will sink down the column any time the head isn't locked (or held on the raise/lower handle)
            Mostly, people mill with the head locked so it might be possible to work this way. Whether it's worth it though …..
            #446195
            petro1head
              @petro1head
              Ok guys sorry.
              since the orginional post i did a full check and adjustment of the x and y axis and they are now much better so decided not to pursue ball screws.
              i am looking at the z axis not from a back lash point of view rather for smoothness and less friction and now understand drawback to ball screws hence why i asked if there was anything better than that std warco setup
              Edited By petro1head on 12/01/2020 19:06:22
              #446199
              Enough!
                @enough
                Posted by petro1head on 12/01/2020 18:58:06:
                People have done this with a cable/pulley counterbalance system. With the counterbalance weight suspended behind the machine.
                Or a gas strut helps.
                #446201
                petro1head
                  @petro1head
                  Posted by Bandersnatch on 12/01/2020 19:04:21:
                  Mine already has a gas strut inside the column. Its more the help the stepper motor
                  Edited By petro1head on 12/01/2020 19:08:18
