Duncan and Martin
I bow to your experience and knowledge. I had not considered the difference in the ratios of the column dia to the fixed distance between the column centre and the spindle centre the difference in the ratios of both multiplying the error achieved.. Thanks to both of you for pointing out alternative thoughts and considerations.
I am currently making a new depth gauge/stop which was broken off when I bought the machine, I shall now modify my designs for this to incorporate the dial indicator suggested by Martin. The idea of a laser is useful however the machine would need to be bolted securely to the garage floor to avoid machine creep and this I did not want to do.
Regards to both of you for your ideas and suggestions.
BobT (Dorsetearman)
