Warco 918 Lathe Tumbler Reverse
Home Forums Manual machine tools Warco 918 Lathe Tumbler Reverse
  • #395703
    Jonathan Garside
      @jonathangarside40968
      I have a Warco 918 and recently saw an article from ME 1 Jan 1993 by J F E Weight about the design and manufacture of a tumbler reverse mechanism.
      Has anyone on the forum made such a unit to the drawings in the article, and if so how did it go. I am looking at any problems or pitfalls, or was it straightforward to make and does it work satisfactorily.
      Jonathan Garside
      Jonathan Garside
        #395889
        Jonathan Garside
          What nobody?
          Jonathan
          #395894
          Andy Carruthers
            @andycarruthers33275
            Would you please post images or link to the article?
            #395920
            Jonathan Garside
              Andy
              I cannot post a link as the only info I have ia a very poor photocopy of the original article as detailed in my first post..
              If you can find the original copy of ME dated 1st Jan 1993 I would be grateful for a better copy myself as I cannot read all the measurements in the poor copy I have.
              Jonathan
              #395925
              Redsetter
                @redsetter
                I no longer have my 918/920 lathe, but I made a tumbler reverse for it based on one of the American designs which are available online. It worked well and was a straightforward modification, using an additional standard change wheel.
                #395926
                Andrew Tinsley
                  @andrewtinsley63637
                  I have done such a mod to a similar lathe. There re several variations on the web, but take a look at "Tricking out the 920" by Steve Bedaire (Sp?). This details one approach and there are several others (See the Yahoo 920 forum).
                  It is simple and straightforward and the modifications are all very similar, although I have not seen the ME version. Well worth the effort.
                  Andrew.
                  #395928
                  Andy Carruthers
                    This appears to be the document Andrew refers to:
                    @Andrew – thanks – very useful
                    #395935
                      Posted by Jonathan Garside on 12/02/2019 11:10:16:
                      There are a couple of originals on ebay at the moment
                      Jonathan Garside
                        Thanks for your replies and I will investigate further the information you have kindly provided.
                        Jonathan
                        #396066
                        John Weight
                          @johnweight34532
                          Hi Jonathan.
                          Re the 918 Tumbler reverse you refer to, I am pleased to say it is still in active use on my own 918 after some 27 years, I have a copy of the relative article in my file and would be pleased to copy it and forward it to you if you would like to PM me.
                          Regards John F.E.Weight.
                          #396090
                          Jonathan Garside
                            Thanks John, PM sent
                            Jonathan
