'Anyway, to the subject in hand, yes there is a lot of backlash. It’s probably takes about ¾ of a full turn of the cross slide to take it out' …
If you have that amount of backlash & tightening the handle doesn't bring it within reasonable tolerance ( there will always be some backlash ) you could try adjusting the leadscrew nut… on my dwg if you look at the nut… part # 44, you will see that there is a slot about 1/4 way in from the rear of the nut, this indicates that there should be some method of closing the gap in the nut ( bolt or SHCS ) hence closing the nut thread onto the leadscrew thread…thus eliminating / reducing backlash to a more respectable amount… worth a try if you can get in from behind… but; considering it's a brand new machine, you have to consider that you will be voiding any warranty if you go diving into any major work, I would definitely talk to Warco about this machine & see what they respond with…
Re. John W1… 'Put it all together and Warco aught to provide you with a free collection and another lathe'…
In my case Warco's sent me the wrong lathe in the first instance including some bad casting work to boot, but a couple of pics in an e mail, a discussion on the phone they soon had it replaced within the week inc. free pick up & delivery, so a lot to be said for their aftersales service… give them a call soonest before you go diving in.
George.
