A lot this morning question and TV program etc.
I used to have an old round column Warco mill and could remove metal with ease using a 3/4” end mill.
Now have a Warco VMC which is fine for much of my work but heavy cuts are not recommended.
My problem is sometimes especially if a cutter digs in the head can be moved and has to be trammed again despite retaining bolts being tight.
When I had use of a large universal mill ( by ME standards) it had a locating pin to set the vertical head true.
Wondered if I can do that to the VMC has anyone done that.
Or are the VMC head castings a little weak to modify?
Thanks for any helpful information to stop the head moving.
Am at the moment milling webs on en24t 150mmØ crankshaft.
A bit of a slow job compared to my speed nut friends CNC machining centre but I enjoy making the parts myself instead of farming jobs out to others.
Been a while since my medical problems and lost a year of model and machining in earnest but now seem to be hopefully firing on all cylinders.
Great to be swarth manufacturing again after seeing a young manual machinist with a young family who lost use of his hand movement etc. in the Ward I was in due to serious cancer.
We became ward friends as both having a love of machining but manual machining has gone for him hopefully training in CNC will keep him in a job he enjoys.
Tonight on BBC1 8pm Without Limits: Vietnam.
Andy Swinging Arm Slade and his group will be in the second episode Andy has been officially timed a year ago at 222mph at Elvington on his motorcycle not bad having only half an handlebar to use.
He might be at Pendine speed record attempts
The Model Engineering and speed attempts whether water or land is like a big family and helpful advice is always available.
