Viton O-Ring safety Valve
Home Forums Beginners questions Viton O-Ring safety Valve
  • #96615
    nigel jones 5
      @nigeljones5
      Does anyone have a drawing for such an item suitable for a 5" Pansy. I believe they seal very well?
      nigel jones 5
        @nigeljones5
        #96822
        Jon
          @jon
          Vitons just a material the O rings made out of and still available in various shores. They last longer and more hard wearing and abround 3 times dearer than nitrile.
          What size and cross section you after?
          #96850
          nigel jones 5
            @nigeljones5
            Thanks Jon
            I wont know that unless someone is kind enough to post a drawing for a safety valve which uses them – anyone?
            Thanks
            #96855
            michael howarth 1
              @michaelhowarth1
              Fizzy…..I have spent quite a lot of time trying to make safety valves using O rings and although I had some successes I also wasted a lot of time. Unfortunately I did not make drawings of the successful valves and they are now on models in Australia but if you pm me I am sure I could remember the essential details.
              Meanwhile, if you Google …….Home builder Parts – Roundhouse …….on about the second para down is mentioned their safety valve…click on technical info. ….. which uses an O ring with a nice drawing of a section through the valve. Let us know how you get on.
              #96868
              nigel jones 5
                @nigeljones5
                will testing on air give the same results as when on steam?
                #96877
                michael howarth 1
                  @michaelhowarth1
                  It did for me to within a psi or two
                  #96922
                  Jon
                    @jon
                    I can see the problems with that design Mick, did the O ring keep dislodging?
                    #96942
                    michael howarth 1
                      @michaelhowarth1
                      Jon…………… there are problems if the O ring is just left "floating" as it were. The ones that I made had a housing for the O ring, roughly midway in the body of the valve. The O ring, was inserted from below followed by a hollow screwed insert, thus holding the O ring captive. There are some careful calculations to be made as to the sizes of orifices and the stainless steel ball and of course the spring. I did not use Viton and found that silicon rings were perfectly OK and cheaper.
                      More recently, I have used Gordon Smith safety valve designs and found them excellent but I still think that O rings have potential as they do produce a foolproof seal.
                      #97053
                      nigel jones 5
                        @nigeljones5
                        Im gona buy one instead!
