Vevor lathe chuck
Vevor lathe chuck
Home › Forums › Manual machine tools › Vevor lathe chuck
  • #626946
    old mart
      @oldmart
      I have just bought a 160mm three jaw scroll chuck on ebay for £54.35 including postage. It was a gamble, but it paid off, fortunately. I mounted it on the Atlas with a tight register on the backplate, and checked the runout. The three scroll pinions gave 0.002", 0.003" and 0.005" with 1" and 2" diameter ground stock at the jaws and about 0.001" more at 3" out with the internal jaws. I was pleased to find that the preferred pinion was the one that is in line with the oiler on the front of the body. The fits are very good for a bargain chuck. I have been looking for a set of external hard jaws for the 160mm chuck that I fitted to it for some time without success. I haven't tried the external jaws for runout, so far.
      #14738
      old mart
        @oldmart
        #627042
        not done it yet
          @notdoneityet
          I think it’s just ‘luck of the draw’ where Vevor are concerned. Good, poor or rubbish is my experience. Reading reviews can be enlightening – but the next batch may not reflect the previous responses.
          #627051
          old mart
            @oldmart
            It is a slightly chancy buisiness, but the investment was low and if a set of hard outside jaws had turned up to fit the other chuck, they would have been about £25, so the risk was worth it. The smaller versions are even cheaper, so anybody with a worn out chuck could get a bargain.
            #627062
            Bill Davies 2
              @billdavies2
              I looked at the Vevor website (https://eur.vevor.com/lathe-chuck-c_10120/k11-100-4-3-jaw-lathe-chuck-self-centering-cast-iron-wood-turning-harden-steel-p_010269150444?v_tag=65253311-89eb-11ed-a9c1-57740b6b1676.1)
              The webpage hints at a chuck for wood (different quality for metalwork?), plus mentions cast iron in the headline, however it claims a hardened steel body, which I doubt. I have no experience of this brand. I have looked at other brands of cheaper lathe chucks, and some of those for wood turning appear to use materials inappropriate for our use.
              I'm not condemning Old Mart for his purchase, I'm glad he's pleased, but adverts do cause me anxiety with their confusing and sometimes contradictory descriptions. That distributors cause confusion is one thing, but one might hope that the manufacturer's own website is unambiguous.
              Bill
              #627064
              old mart
                @oldmart
                I think this was the place I bought the chuck from:
                  Posted by Bill Davies 2 on 01/01/2023 15:57:51:…
                  Bill
                  Vevor is a distributor, not a manufacturer. They aren't even a tool specialist. The advantage of buying from them is low cost, not certain delivery of high-specification tooling. What people get is a bit risky, but as Old Mart and others have found, what arrives is often acceptable.
                  The name 'Vevor' doesn't guarantee quality: if a particular item turns out to be a dud, the customer detects the fault and asks for a replacement or refund. It's not like buying a Pratt Bernerd or similar. Industrial products meet much higher quality requirements, which would be good except the customer pays for lots of inspections, many of which make perfect sense in an industrial setting but are over the top in a hobby workshop.
                  old mart
                    @oldmart
                    Exactly, SOD, most of us are not producing NASA or aerospace parts, so top quality in everything is not essential. some people are struggling to keep a chuck going despite knowing that even a cheap new one would probably be a better bet, even top quality wears out eventually. I would like a new chuck, but not for £500.
                    Edited By old mart on 01/01/2023 18:36:19
                    #627101
                    jaCK Hobson
                      @jackhobson50760
                      Vevor 2 axis DRO is brilliant. The 7" angle plate needed attention with an angle grinder to get it to go to 45 degrees – but otherwise great. The Ball Vice needed some slight fettling but is now brilliant. Delivery is brilliant.
                      The Vevor Induction forge… can be bought about £200 cheaper on ebay.
                      #627103
                      john halfpenny
                        @johnhalfpenny52803
                        I have a Vevor 5 inch 4 jaw chuck. Nicely made and very inexpensive – I think I paid about £ 80ish including delivery. A big improvement over the knackered 4 jaw I was struggling with.
                        #642664
                        vic newey
                          @vicnewey60017
                          Posted by john halfpenny on 01/01/2023 19:15:30:
                          I'm looking to buy 5" 3 jaw one of these, there is one mounted on my Vevor indexing head and I took the chuck off to have a look at it with the backplate off. It has three Allen key bolts on the back, I removed them after a struggle as really tight, now I can't get the actual backplate itself off no matter what I try, has anyone managed to get it off and if so how did you do it?
                          #642671
                          john halfpenny
                            @johnhalfpenny52803
                            If it's a disc sitting in a recess,it's probably just a very tight fit. Maybe try to rotate it with some lube around the edge.
                            #642673
                            Ady1
                              @ady1
                              I've never had a baddie from them yet. One item went awol.
                              Thing is, their basic items save a lot of effort for not too much moolah and you can sort out any shortcomings yourself
                              Got some very capable basic welding stuff before it got sold out
                              If you're in the CNC market it's definitely worth keeping an eye on them for useful bargains
                              Edited By Ady1 on 26/04/2023 13:16:23
                              #642675
                              vic newey
                                @vicnewey60017
                                Posted by john halfpenny on 26/04/2023 13:07:26:
                                I've tried that, it must be really tight, I'll have another go, Every chuck I've ever owned comes away easily when you undo the bolts but not this one
                                #642716
                                Andy Stopford
                                  @andystopford50521
                                  Posted by vic newey on 26/04/2023 12:10:04:
                                  Same with mine – I had thought of using it on my rotary table but it defeated my (not very intensive) attempts at removing the backplate so I bought a another chuck just to use on the RT. Maybe its all a fiendish plot by Vevor to maximise chuck purchases.
                                  #642718
                                  Pete Rimmer
                                    @peterimmer30576
                                    Posted by jaCK Hobson on 01/01/2023 19:00:48:
                                    Does the DRO report the correct position if you move the axis with the power off?
                                    #642754
                                    Martin Connelly
                                      @martinconnelly55370
                                      I have a Ø160 chuck that only had outside jaws with it when I bought it used. I found some soft jaws and inside jaws for it on the WWW. I put the inside jaws on the chuck and did a check and there was excessive runout but I knew the scroll and main body were good. I jammed the jaws tight with spacers between the parallel faces between the jaws. I then bored the jaws with a large boring bar and some **GT inserts taking off 0.15mm in 0.05mm steps from just touching the high spot to cleaning off all the marker pen I put on the contact faces. No runout issues now. I have machined HSS with these inserts so I had no worries with using them on hard chuck jaws.
                                      So there is a quick and simple alternative option to grinding the jaw faces if the scroll and chuck body are good but runout is unacceptable.
                                      Martin C
                                      #642763
                                      Jelly
                                        @jelly
                                        Posted by Pete Rimmer on 26/04/2023 19:53:10:
                                        No, but that's pretty normal for a DRO kit.
                                        You can only have that behaviour with absolute position scales (like Mitutoyo Series 539 AT[###]), and a compatible Readout/Counter unit…
                                        Which are really quite pricey compared to the incremental scales used by every clone of the very widespread Sino DRO (of which Vevor is one) and most of the standard options from other manufacturers (including Newall, Easson, Acurite, m-dro and others).
                                        #642767
                                        Howard Lewis
                                          @howardlewis46836
                                          If the backplate is, thanjfully, a tight fit in the register on the chuck, you could drill teo diametrically opposed holes and tap them (M6 perhaps ? ) and use these holes with jacking screws to pull the backplate off.
                                          The holes for tapping only need to just go through the backplate far enough for the bottoming tap to do its work.
                                          #642773
                                          Martin Connelly
                                            Howard, you can grind the threads off a short length of the jacking screws as well to push on the bottom of the hole where you have drilled into the chuck.
                                            Martin C
                                            #642994
                                            Chris Crew
                                              @chriscrew66644
                                              If the chuck was made by San Ou you will be quids in! I bought an 8" 4-jaw self-centring chuck for £108, including VAT & shipping, and the quality and accuracy for the price is excellent. So cheap I thought it may be a scam. It cost me another fifty-quid for a well used L0 back-plate. It needed an interstitial plate making and I took a lot of trouble over this when machining the register, but when fitted a 0.625" ground test bar showed a run out of less than 0.0015" when measured six inches from the chuck jaws. I don't even bother with the Burnerd 3-jaw now except when the need arises to grip a hexagon.
                                              Edited By Chris Crew on 28/04/2023 20:58:13
                                              #642997
                                              Emgee
                                                @emgee
                                                Chris
                                                There was a link to a 4j SC chuck holding hex bar a few days ago, can't remember the topic though.
                                                Emgee
                                                Found the link, thanks Michael
                                                http://rotagriponline.com/Photos/4%20Jaw%20SC%20chuck%20Hex.jpg
                                                Edited By Emgee on 28/04/2023 22:08:14
