Unimat SL belts & bearings
Home › Forums › Workshop Tools and Tooling › Unimat SL belts & bearings
  • #64757
    rofor
      @rofor
      Hi from Ro in North Devon,
      I have picked up an old Unimat SL which requires new belts, plus new headstock and idler bearings. I`m hoping some other Unimat users here might be able to offer advice.
      I am uncertain if I should use round belts 4mm wide as currently on sale on ebay or 5.3mm.
      Regarding replacement bearings, e13 and e6 are mentioned and I am hoping for advice on where to buy them. These bearings seem to be termed magneto bearings.
      I reluctantly parted with my Harrison 140 and Harison univeral mill a while ago because of disabilities but am looking forward to tinkering with a small lightweight bench lathe.
      Any help in pointing me in the right direction would be much appreciated.
      #16624
      rofor
        @rofor
        #64759
        KWIL
          @kwil
          e13 Magneto bearings are 13mm OD, try http://www.akbearings.co.uk Arc Euro Trade has e6. I do not know about Unimat belts.
          #64772
          V8Eng
            @v8eng
            Hi.
            Try this, it lists lots of parts for many makes / models.
            Edited By V8Eng on 27/02/2011 19:33:59
            #64774
              This guy does belts & bearings, not sure what postage from the US will be
              #64775
              Nicholas Farr
                @nicholasfarr14254
                Posted by KWIL on 27/02/2011 12:31:20:
                Hi Kwil, I think you ment to say that the ID is 13mm, i.e. the bore. The OD being 30mm and the width 7mm.
                Most bearing distributers supplying industry should be able to supply you with any available bearings and most of them accept cash sales.
                Regards Nick.
                #64776
                David Clark 13
                  @davidclark13
                  Hi There
                  Use O-rings for Unimat belts.
                  Works out at about 50P each.
                  I think I gave sizes in MEW 124 or just after.
                  If you are a subscriber, you can access them in the archives.
                  regards David
                  #64777
                  Keith Long
                    @keithlong89920
                    Just do an internet search on “magneto bearings” you’ll find a number of stockists. Price seems to be about £5.50 + vat each for those sizes.
                    Keith
                    #65162
                    Niloch
                      @niloch
                      Unimat belts: two friends got fed-up with paying silly prices for the required belts. They clubbed together and bought suitable ‘O’ rings from here.
                      #65178
                      Ian S C
                        @iansc
                        Why not use heat joinable plastic belting, it gives a more possitive drive than ‘O’ rings, it lasts well, if it breaks join it again. It does’nt stretch as ‘O’ rings do. If you have choice between 4mm and 5.3mm, use 5mm belting, thats the stuff I use on my Super Adept, it could actually be OK with down to 3mm that what I use to drive off my Hot Air Engines.
                        Ian S C
                        #65185
                        ady
                          @ady
                          The 5mm belting I used on my wee unimat protruded beyond the pulleys, even at 4.68 mm it’s still too big and would catch on part of the lathe when on its most extreme drive wheel settings.
                          The 4mm belting sits inside the pulleys and has no interference issues.
                          It’s easy to check, use a drill bit of 4mm and 5mm and see how they fit, even a 4.5mm drill bit wont fit into my own pulleys.
                          Edited By ady on 08/03/2011 11:42:09
                          #65186
                          dcosta
                            @dcosta
                            Hello rofor!
                            In the eighties I had a Unimat3 and faced the same problem You are facing now.
                            And also tried the o’rings of the common kind, perhaps made of rubber. And they failed after some hours of light work.
                            Maybe the variety made of Viton whose mechanical properties I ignore is better for the purpose.
                            The pulleys in Unimat 3 had a round profile and I think the same goes with Unimat SL. If so, You should take in consideration You mustn’t use trapezoidal belts with Unimat SL.
                            Warning:
                            Viton is incompatible with aceton and organic acids such as acetic acid.
                            Note:
                            For more information on Viton see: http://en.wikipedia.org/wiki/Viton
                            Best regards
                            Dias Costa
